Stubby Posted November 7, 2011 Report Share Posted November 7, 2011 I recently just purchased these ubolt from summit racing. They meet all the specs for the wagon rear axle. I should have them installed in the next couple weeks. I can come back and update the thread when they are installed. I will be using these ubolt with 2" blocks to begin with. If I am not satisfied with that drop I will be flipping a spring. Here is the link.http://www.summitrac...arts/TRA-40003/ 1 Quote Link to comment
Stupid_fast Posted November 7, 2011 Report Share Posted November 7, 2011 I have a set of these, they fit nicely on the axle. Unfortunately I don't have blocks to go with them yet so I don't have them installed. Quote Link to comment
Jewosh Posted January 31, 2012 Report Share Posted January 31, 2012 Does anyone know about getting wedged blocks? Like with a 4 degree angle to offset the driveshaft pinion angle. SOmeone told me Summit has some but I couldn't find them Quote Link to comment
Laecaon Posted January 31, 2012 Report Share Posted January 31, 2012 I have heard of just the wedges. So they just sit on any block you have currently. Quote Link to comment
Stupid_fast Posted February 1, 2012 Report Share Posted February 1, 2012 Never heard of those, but that would be really useful for my setup as I have just flipped the leaf, the pinion angle would really help things as the front of the diff is the closest to the chassis. edit, found them!! http://www.summitrac...n%20angle&dds=1 What is correct for our goons? They have 2, 4, 6 degree ones. Quote Link to comment
Just Joel Posted February 1, 2012 Report Share Posted February 1, 2012 3* is perfect for 2.5" lower than stock... Later Joel Quote Link to comment
Jewosh Posted February 4, 2012 Report Share Posted February 4, 2012 Never heard of those, but that would be really useful for my setup as I have just flipped the leaf, the pinion angle would really help things as the front of the diff is the closest to the chassis. edit, found them!! http://www.summitrac...n%20angle&dds=1 What is correct for our goons? They have 2, 4, 6 degree ones. Someone told me they used the 4 degree with a 2 inch block I believe and a leaf flipped. I have a leaf flipped but I'm going to throw a block in there too! Thanks for finding them! Quote Link to comment
Jester Posted February 5, 2012 Report Share Posted February 5, 2012 Suzuki Samurai U-bolts are the same dimension as the wagon as well. If I remember correctly, the early Mustang was too. Quote Link to comment
datzenmike Posted February 5, 2012 Report Share Posted February 5, 2012 I got a set of 2" and U bolts for a 620 at Canby. I made them fit my H-165 axles in my 710. Just hammered the wider U bolts in slightly. Quote Link to comment
pecx Posted September 22, 2017 Report Share Posted September 22, 2017 Any suggestion for what available now in 2017? Quote Link to comment
nullbound Posted September 23, 2017 Report Share Posted September 23, 2017 I just ordered these for my 510 wagon: http://www.jegs.com/i/Superlift-Suspension-Systems/426/10643/10002/-1?CAWELAID=230006180000866076&CAGPSPN=pla&CAAGID=44693592161&CATCI=pla-177214861511&CATARGETID=230006180039217819&cadevice=c&gclid=CjwKCAjw_8jNBRB-EiwA96Yp1iawCbSu7NurnA8GOD92mowisZnfAwPBotJf4w8lvhUSZj6v49mouRoCVeEQAvD_BwE Quote Link to comment
datzenmike Posted September 23, 2017 Report Share Posted September 23, 2017 $40 for U bolts??? Quote Link to comment
Duncan Posted October 12, 2017 Report Share Posted October 12, 2017 I gave my local spring shop the dimensions I needed for U bolts, and they made them while I waited. I think they were about $25-ish. Quote Link to comment
edekalil Posted October 13, 2017 Report Share Posted October 13, 2017 Someone told me they used the 4 degree with a 2 inch block I believe and a leaf flipped. I have a leaf flipped but I'm going to throw a block in there too! Thanks for finding them!When y'all say a leaf flipped do you mean you flip the leaf spring over? Or is it a special made leaf spring different shape? I have a stock Goon and have the 2" blocks and U bolts. If I use them with the stock leaf springs what degree wedge would you say I should use? Quote Link to comment
