bryant2482 Posted November 3, 2011 Report Share Posted November 3, 2011 i was driving down the road today and when i went to shift into 5th gear my speedometer stopped working. anyone else experience this problem? Quote Link to comment
izzo Posted November 3, 2011 Report Share Posted November 3, 2011 perfect timing for the cable to shit out? haha. Quote Link to comment
bryant2482 Posted November 3, 2011 Author Report Share Posted November 3, 2011 perfect timing for the cable to shit out? haha. oh the cable isnt broken. my speedo drops as soon as i shift into 5th. then when i put it back in neutral or the other gears it works! doesnt make ant sense to me Quote Link to comment
izzo Posted November 3, 2011 Report Share Posted November 3, 2011 It was a joke I don't know why it would do that. Crazy, though. Quote Link to comment
datzenmike Posted November 4, 2011 Report Share Posted November 4, 2011 oh the cable isnt broken. my speedo drops as soon as i shift into 5th. then when i put it back in neutral or the other gears it works! doesnt make ant sense to me Does it work when coasting in 5th with the clutch in???? Quote Link to comment
bryant2482 Posted November 4, 2011 Author Report Share Posted November 4, 2011 Does it work when coasting in 5th with the clutch in???? nope not at all. before it happened i was in 5th gear and i was hearing a very very small grinding noise then put it back into 4th. i just had the tranny rebuilt in july with new bearings and seals Quote Link to comment
datzenmike Posted November 4, 2011 Report Share Posted November 4, 2011 Thing is the speedo drive worm gear is on the output shaft behind 5th gear. The speedo pinion cog is mounted just below and to the pass side. Forth gear transmits power straight through the tranny but other gears, specially 5th is driven by the counter shaft below it. Under load the two shafts will develop a side load and try to force each other apart. If the mainshaft lifts it will lift away from the speedo cog and if bad enough it will disengage. You say it was rebuilt so this should not be happening. Very interesting. Quote Link to comment
datsunaholic Posted November 4, 2011 Report Share Posted November 4, 2011 As Mike said the only way the speedo cog can disengage is of the output shaft moves away from it. I suspect you've lost a bearing or bushing on the output shaft and the transmission will self-destruct fairly soon if you don't fix it. The grinding noise was the bearing letting go. Just because it was rebuild doesn't mean it was rebuilt correctly. Quote Link to comment
bryant2482 Posted November 5, 2011 Author Report Share Posted November 5, 2011 As Mike said the only way the speedo cog can disengage is of the output shaft moves away from it. I suspect you've lost a bearing or bushing on the output shaft and the transmission will self-destruct fairly soon if you don't fix it. The grinding noise was the bearing letting go. Just because it was rebuild doesn't mean it was rebuilt correctly. yea thats true. well thats cottman transmission for ya! they took 2 weeks to rebuild my tranny last time. all new bearings and seals (so they say). its still under the 6000 mile warranty. Quote Link to comment
datzenmike Posted November 5, 2011 Report Share Posted November 5, 2011 Just because it was rebuild doesn't mean it was rebuilt correctly. ... or with quality parts. Quote Link to comment
ronnny Posted November 5, 2011 Report Share Posted November 5, 2011 I looked on a google search and did not find a lot of people complaining of this like the fifth gear noise/clinking problem. But i am with the others on a bearing walked out of its spot and is making the shaft back away from the the speedo gear. I think most of the time from what i read is that hapens is like mine the counter shaft the other gears than 4th are using looses a bearing on the fifth gear end and end up with a noise like mine has. It works but makes a racket like a lot of backlash or open space in the gears. You find my problem in lots of places if you search. For you that bushing or bearing on the output shaft has came out. Get your warrenty stuff done and make them start over on your time again. My tranny is supose to have 230k on it. Quote Link to comment
bryant2482 Posted November 6, 2011 Author Report Share Posted November 6, 2011 I looked on a google search and did not find a lot of people complaining of this like the fifth gear noise/clinking problem. But i am with the others on a bearing walked out of its spot and is making the shaft back away from the the speedo gear. I think most of the time from what i read is that hapens is like mine the counter shaft the other gears than 4th are using looses a bearing on the fifth gear end and end up with a noise like mine has. It works but makes a racket like a lot of backlash or open space in the gears. You find my problem in lots of places if you search. For you that bushing or bearing on the output shaft has came out. Get your warrenty stuff done and make them start over on your time again. My tranny is supose to have 230k on it. yea im taking it to them first thing monday morning! i was driving and now my speedo doesnt work at all. the trans doesnt make any funny noise at all either. ive just been driving in 4th the past few days. im going to pull off the speedo cable off the transmission on the morning and try to look inside Quote Link to comment
Skulptr Posted November 6, 2011 Report Share Posted November 6, 2011 I wouldn't, if something broke, and you mess with it, that will "void" a warranty, at least thats what any half arsed tranny shop will claim, so they don't have to fix it Quote Link to comment
datzenmike Posted November 6, 2011 Report Share Posted November 6, 2011 If they rebuilt it maybe best to take it back to them with your complaint. See what they do about it. I wouldn't go any further than removing the cable. (left) not the pinion (right) . Quote Link to comment
bryant2482 Posted November 6, 2011 Author Report Share Posted November 6, 2011 I wouldn't, if something broke, and you mess with it, that will "void" a warranty, at least thats what any half arsed tranny shop will claim, so they don't have to fix it ok yea im not gonna mess with it then. is there a key built into the speedo gear? Quote Link to comment
datzenmike Posted November 6, 2011 Report Share Posted November 6, 2011 There is a ferule on the cable end that locks into the pinion in the transmission. The pinion is slotted and held in position by a 'key' and 10mm bolt. Quote Link to comment
