DeRuX Posted October 17, 2011 Report Share Posted October 17, 2011 When I first got my hako the license plate was only held on be one bolt. I looked into why and noticed that the japanese license plate holes are wider then the US plates. I didn't want to drill hole in my plate and I also wanted to run a license plate frame. So I made a set of these brackets to mount my plate. After seeing other JDM cars with drilled out plates. I thought that maybe other people with JDM cars would like a set of these too. Because they offset the holes. If you mount them the other way they can be used on US car to install JDM plates. These are made from stainless steel and have stainless steel PEM nuts pressed into them. They come with a set of M6 low-head allen screws and stainless washers. I am asking $15 for a pair shipped. I take paypal. Link to comment
MikeRL411 Posted October 17, 2011 Report Share Posted October 17, 2011 When my RL411 was assembled the factory installed the license plate tapped insert plates in the rear trunk panel "backwards" so that they have JDM spacing, not the USA standard spacing. I guess no one told them it was an export version. I could have removed and rewelded the tapped plates in the "right" USA spacing but said "WTF, that's the way it was made" and punched 2 holes in the rear license plate. The front plates fit the bumper "as built". When I keep a car in factory built configuration, it extends to preserving screw ups in assembly. Link to comment
VoidDragon Posted October 18, 2011 Report Share Posted October 18, 2011 Ive drilled holes in several plates. Especially on my motorcycle. Link to comment
DeRuX Posted October 18, 2011 Author Report Share Posted October 18, 2011 When my RL411 was assembled the factory installed the license plate tapped insert plates in the rear trunk panel "backwards" so that they have JDM spacing, not the USA standard spacing. I guess no one told them it was an export version. I could have removed and rewelded the tapped plates in the "right" USA spacing but said "WTF, that's the way it was made" and punched 2 holes in the rear license plate. The front plates fit the bumper "as built". When I keep a car in factory built configuration, it extends to preserving screw ups in assembly. That is crazy. I wonder if it was built on a friday. LOL Link to comment
MikeRL411 Posted October 18, 2011 Report Share Posted October 18, 2011 That is crazy. I wonder if it was built on a friday. LOL The 411s have a pocket on the rear sheet metal for the about 1/8 inch thick tapped steel plate for the license plate attachment. Spot weld to the left or right for appropriate bolt hole spacing. Apparently assembly line worker Toshio Watanabe [the Japanese John Q Public] wasn't told, or didn't read the build sheet, and set me up for JDM plates. Link to comment
DeRuX Posted January 16, 2012 Author Report Share Posted January 16, 2012 New batch now ready for sale Link to comment
DeRuX Posted February 6, 2012 Author Report Share Posted February 6, 2012 Made some more sets. Here are some more photos of how they work The white car is my skyline and the red car is a US car. So you can see they you can use them both ways. Link to comment
tycot1 Posted February 7, 2012 Report Share Posted February 7, 2012 me like, i will check if one of my customers needs a pair. Link to comment
chingpo Posted May 10, 2012 Report Share Posted May 10, 2012 Please send me a quote for 1 pair please. Link to comment
DeRuX Posted June 6, 2012 Author Report Share Posted June 6, 2012 new batch in. They now come with button head screws. Link to comment
DeRuX Posted July 10, 2012 Author Report Share Posted July 10, 2012 bump to the top 1 Link to comment
