datzenmike Posted December 28, 2011 Report Share Posted December 28, 2011 520s had the 4.875 in the aluminum case. Quote Link to comment
LeX Posted December 31, 2011 Report Share Posted December 31, 2011 so can I drop h190 disc rear end in my h190 72 510 Wagon? Quote Link to comment
datzenmike Posted January 1, 2012 Report Share Posted January 1, 2012 The S110 is coil spring and link whereas the goon is leaf. Have no idea what the width is. Ask the guy to measure from wheel mounting surface to wheel mounting surface and compare to your goon. The coil a link mounts can be removed with a blue tipped wrench and ground down with an angle grinder and some time. Make up a pair of spring perches and weld them on. . Quote Link to comment
prophet1012 Posted January 30, 2013 Report Share Posted January 30, 2013 Those rims <3 Quote Link to comment
datswag80 Posted June 7, 2014 Report Share Posted June 7, 2014 Hey bro I have a wagon with 1 solid driveshaft did yours bolt right on? Quote Link to comment
ggzilla Posted June 7, 2014 Report Share Posted June 7, 2014 Wagon and sedan use the same driveshaft. Quote Link to comment
datswag80 Posted June 8, 2014 Report Share Posted June 8, 2014 Ok cool thanks a lot could have used the same arms ? Quote Link to comment
ggzilla Posted June 8, 2014 Report Share Posted June 8, 2014 I've heard you use the 200SX arms or the 210 arms Quote Link to comment
datswag80 Posted June 8, 2014 Report Share Posted June 8, 2014 Dang ok because I payed extra at the junkyard for them lol Quote Link to comment
