1980 200sx h165?
80datson
  • Replies 33
Famous last words. lol
The 210 has an H-150-A rear axle and is 2 inches shorter (wheel tread) than the 200sx but the width could be the rim offset. An H-165-B is not the same as an H-150-A. Although they may have 4 link and coil springs and the e brake pulling across the back the 210 uses pressed in U joints that are likely smaller than the 200sx and probably the drive shaft won't bolt to the 200sx diff flange. There may be subtle differences in link length, coil mounts, shock mounts. Measure carefully.
a later 200sx H190 will also fit and with stock datsun wheels, might have to roll fenders if you want super low like this pic of my B310 w/ 200sx H190(no springs for the pic):
one more thing... this would never happen if there was a 3rd member installed unless the trans tunnel was cut out.
  • 2 months later...
thanks dude! yeah one day i want to have a race on the strip with Burleigh and settile which is the best. round nose or square nose! :P
Haha! Just saw this one...
Square is faster, but round gets the "chikas"...!
Nice build by the way!
