* * * * * 11 votes
'73 1200 Coupe Project, aka Timmy
  • Please log in to reply
1706 replies to this topic
#1641 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
  • Cars:'73 1200 Coupe, '77 280Z
Posted 26 January 2018 - 02:29 PM
Good point. How do you mount those in a 1200 though? Looks like the tech info says to bolt through the floor and you would have to probably cut out all the factory risers
Mine was bolted to the factory slider. But to the floor would be a lot lower.
Were it mine, floor. But I'm 6' 3" so the utes aren't really built for me...   ^_^
It's your car, just don't ruin it.
This seems like an elaborate ploy to get me to say "I like the D".
#1642 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 26 January 2018 - 02:30 PM
That rear seat looks a damn sight better than the last time I saw it.
They were very thankful to have the old cover to use as a pattern, though.   :thumbup:
#1643 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 27 January 2018 - 11:54 AM
So I attempted to first make the stripe on the rear door panels shiny again with some of this super thin aluminum tape...
large.20180127_094710.jpg.63625a9f6c182f
It looked terrible.  :rofl:
So I peeled that off and decide paint was the way to go...
large.20180127_100814.jpg.05d7b3d9a1bb25
While not perfect, that worked a lot better...
Got both sides done and reinstalled, so I decided to go ahead and throw the seat in there to see how it looks...
large.20180127_124749.jpg.6e30c7c3bfb25b
I wanted to see how much "leg room" there was with the front seat installed in my preferred position...
large.20180127_125843.jpg.ccda5722c3672d
And it ain't much...   :rofl:
i never had any intention of anyone sitting in the back seat anyway, but there can be no doubt now. It's more of a parcel shelf than a seat...   :thumbup:
#1644 njoz1200ute
njoz1200ute
  • Senior Member
  • PipPipPipPip
  • 662 posts
  • Cars:1976 and 1980 Datsun B120 Utility "1200 ute"
Posted 27 January 2018 - 12:56 PM
I sat in my coupe backseat once and pulled both seats back to see how much legroom there was.....so little room that in fact I had to call my nephew to come rescue me from the backseat because I couldn't reach the seat sliders on my aftermarket seats.
#1645 dimlight65
dimlight65
  • Senior Member
  • PipPipPipPip
  • 892 posts
  • Cars:A Smart ForTwo, a Lotus 7, a Datsun 1200, and a Ford Falcon Econoline Van
Posted 28 January 2018 - 06:46 AM
I can see the Bring a Trailer ad now:
"If you can stand the smell, this is the Datsun for you.  And you may keep the skeleton."
"Gnorts, Mr. Alien!" Neil Armstrong
"It's like a fine cognac... with a hint of aged scrotum"  Bender B. Rodriguez
That color is called Statutory Grape
#1646 TSKB310
TSKB310
    Advanced Member
  • Members
  • PipPipPip
  • 119 posts
  • Cars:79 KB310
Posted 31 January 2018 - 01:44 PM
Looks to be plenty of room for Lt. Dan.
#1647 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 03 February 2018 - 03:30 PM
Although you probably can't tell, this is about 1" lower and about 1" father back...
large.20180203_114524.jpg.ffbc12a11945d8
I ended up trimming the front brackets so they would sit lower, then mounted them to the back side of the seat rail. Still really solid, but lower and father back.
Because of that, I got some 1" box and remade my rear spacer...
large.20180203_105737.jpg.3c5bf20af0d9ef
Then put that in for a test sit...
large.20180203_120802.jpg.bae3c716e68acb
I think this is the final spot. It's low enough, and far enough back, to be comfortable. I have about 2" between my head and the headliner, so I think we're good...   :thumbup:
While I was sitting there, I decided to see how the 6pt harness fit, and immediately noticed a problem with it. Since the old seat had a hole in the middle for the sub strap to go up through, and this seat does not, it is now too low. The camlock hits me right in the testicles. Which is waaaay too low. So I stretched it out and marked where it sat...
large.20180203_120145.jpg.e92cf0b959e016
They were bolted down with the stock seat belt bolts, but since they were adjusted all the way out already, I had to change that. I unbolted them and put some fresh holes in the floor under the seat, then adjusted them up to get the camlock about 4" higher...
large.20180203_132004.jpg.eed8fdf31096ca
That should be much better, but there's now a lot of adjustment leftover if it needs to go higher...
After that I cleaned up and repainted the seat rail since I scratched the hell out of it doing all this mockup.
Next week I will be dyeing the seat and reinstalling it (hopefully) for the last time...   :thumbup:
#1648 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 11 February 2018 - 05:43 PM
Weather was too damn cold to dye the seats so I got on to some other things that needed doing...
Was head scratching on how to get speaker wires from the front to the back since the PO had already installed new carpet but had glued it down. I found a spot where he had spliced two pieces together on the side of the transmission tunnel, so I pulled that up, hid the wires under it and glued it back down.  :thumbup:
We looked at a few different options for mounting the rear speakers but none of them seemed ideal, so for now I have taken what Tim calls the "ghetto" approach and just did this...
large.20180210_113933.jpg.1e5b3a6a81b095
I think the right side will stay still due to the harness holding it in place, but the left side would be free to move around. After looking at way to fix that I came up with two options. Either a tether from the back of the box to the floor behind the seat, or attaching it to the other speaker box to limit movement.
I found this in the parts bin...
large.20180210_114907.jpg.2b80b98a02778c
So thinking I will use that (probably also doubled up with a piece of steel) as a bar between the boxes to keep them from moving about the seat...
#1649 ]2eDeYe
]2eDeYe
    Bastard!
  • User Administrator
  • 18,103 posts
  • Cars:78 620 KC, 77 620 KC, 72 CJ5, 04 G35 coupe mmmm
Posted 11 February 2018 - 06:14 PM
What are you using to dye the seats?
Smokin' Joe's House of Datto's
Member- *Japanese Trucking Association*
**DATSUN FAQ** ~ If ya know it, post it ~ If ya don't know it, learn it ~
ratsun.net rising sun stickers                     ratsun business cards order thread
620 KA24 Motor Mount Swap Brackets
1977 620 KingCab Deluxe KA24DE Swap - Refresh and cleanup
1978 620 kingcab 4x4 - KA24E SAS w/Dana 44 front and Toyota rear
1967 RL411 Station Wagon
Whenever I think that I'm out of my mind for putting this much time and money into an old Datsun, all I have to do is look some of your threads to know that I'm not nearly as whack as you are.
You're going to skin a few knuckles, stand up too fast and bump your head, hunt around the floor for the nuts and bolts you dropped, invent a few new cuss words and when you're finished you'll say "That wasn't so hard after all!"
#1650 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 11 February 2018 - 06:23 PM
SEM color coat in Shadow Blue. Also used it on door panels as well. It's a super close match to the stock blue used in 1200s.
#1651 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 17 February 2018 - 01:55 PM
Got the seat all scrubbed up and ready, then set it out in the sun to heat up a little...
large.20180217_102745.jpg.7eb862bd4bb5a2
And the after shot...
large.20180217_104823.jpg.375a0a1b8504b5
Started to put the side trim back on and noticed the clip that holds the front on was broken. Used Tim's trusty soldering iron to "weld" it back together. Since they are made of nylon, it's easy to weld it back together. And as a side note, some aerosol paint can lids are made of nylon too. I cut one of those up to use as "welding rod". It's hideous, but strong, and no one will ever see it in the car...
large.20180217_111632.jpg.dfe09bfdedb420
It was a bit dingy so it and the adjuster handle cover were repainted before install...
large.20180217_120009.jpg.20bfe4d7e67ccc
Also cleaned and repainted the harness holders, screwed those in, then bolted it into the car...
Hopefully for the last time...   ^_^
large.20180217_123744.jpg.1049d3c15465ce
Now to see how to make the passenger side fit. It has slightly different mounting brackets, so hopefully some of this translates to that...
#1652 ]2eDeYe
]2eDeYe
    Bastard!
  • 18,103 posts
Posted 26 February 2018 - 06:07 PM
That looks tight right there. :cool:
#1653 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 27 February 2018 - 12:56 PM
Yeah, any seat made for a wide American ass is not an easy fit in a 1200...   ^_^
#1654 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 27 February 2018 - 03:17 PM
Got some rear seat ash trays from Kelmo!  :thumbup:
large.20180227_162716.jpg.69af659e0ee1ab
And some cool metal wall art for the garage...   B)
large.20180227_162644.jpg.411e3afe263f34
#1655 KELMO
KELMO
  • Senior Member
  • PipPipPipPipPip
  • 2,171 posts
  • Cars:71 Goon, 72 1200 coupe x 2, 69 F250 72 510 4DR Sedan 2003 Maxima 2014 Frontier 2012 Xterra
Posted 28 February 2018 - 09:00 AM
We are hoping to do some more of those in the future.  Possibly some 510, the 510 " Datsun script and maybe a Datsun emblem......possibly.
NISMO: Nissan Impresses Sluts More Often
"Well, primer gray IS a color..." (quote: Kelmo's wife)
#1656 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 03 March 2018 - 04:10 PM
Ash trays were blue, but not the "correct" blue, so a scrub up and some paint later...
large.20180303_092507.jpg.01344a32574301
And installed...
large.20180303_093931.jpg.e904fbcea34a50
So yet again spending time on things that are cool that no one will ever see, or use...   :rofl:
While I'm dyeing all the interior to one consistent blue, I figured the front door panels ought to be next. So out they came, and one scrub up and paint later...
large.20180303_130258.jpg.3b2e0741fc1644
While I had those out, I thought it was a good time to address something about the car (and all 1200s) that has been bothering me. Why didn't they make the door panels go all the way to the bottom of the door? Why leave a 4" wide strip of body color at the bottom of each door? It's annoying when everything inside the car is black or blue and you have this glaring white stripe on each door, so...
Took a scotch-brite to the paint and then threw some tape on it...
large.20180303_114659.jpg.32f7ddd17f0e11
Couple of thin coats of satin black to keep the white from bleeding through...
large.20180303_114852.jpg.f75c1650586db2
Then a few coats of the appropriate blue...
large.20180303_123516.jpg.bd90db4374682d
Once the panels are back on, I think this will really tie the room together...   :thumbup:
I decided not to reinstall them today because I want to give the door panels plenty of cure time before I mask them to repaint the silver stripe like I did on the rear panels. Then I will polish up all the chrome bits before reinstall...
Also waffling on the door pulls currently. They do poke me a bit in the side, so not sure if they will stay or go. If they stay, I will probably dye them blue as well. If they go, perhaps something will go in their place like possibly just a leather strap?
#1657 ]2eDeYe
]2eDeYe
    Bastard!
  • 18,103 posts
Posted 04 March 2018 - 09:36 AM
That is a great idea.
#1658 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 04 March 2018 - 01:31 PM
The painted door or the leather strap?   ^_^
If door, I agree. I think this would be a good idea for 510s and 620s too...
#1659 ]2eDeYe
]2eDeYe
    Bastard!
  • 18,103 posts
Posted 10 March 2018 - 01:53 PM
The door.
#1660 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
Posted 10 March 2018 - 01:58 PM
Got busy with some other stuff but had time to finish the passenger side panel...
large.20180310_131643.jpg.1c1252fd81db53
Not flawless, but I think it looks pretty good...
large.20180310_133459.jpg.baf33f726e72ec
Got it reinstalled but ran out of time to polish the chrome bits before putting those back on, so more pics soon...
