Haubstr 521
This is what my dad and I did this weekend... It's not finished but it is a good start...
From this:
To:
Just put the bondo on but haven't start sanding it off yet... It won't have alot of bondo when we are done...
And look NO HOOKS... LOL
  • Replies 55
  • 3 years later...
a couple of updates finally...
BeeBani brackets and discs
Proportioning valve for the 4 wheel discs
Fromt Side view
Rear
Inside
New goodies
looks good
where you get the Blu Streak cap? they still make them.I cant find them anymore
Good luck on finding a Blue Streak cap... I actually found this one on amazon... I fired up the truck and ran it for a few minutes, took off the distributor cap and the center pin that touches the rotor fell out... Needless to say no more blue streak cap
Fromt Side view
Rear
Inside
New goodies
Nice work.
couple of more pics...
Shot of proportioning valve for the 4 wheel discs and the long tube header...
Interior...
The mirror I found on his 520 parts trucks...
looks good
here is one on flea bay http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=320726238155
Good find for the stock single point distributor which I have in my 510 w/Pertronix, but my truck has a black box dizzy which I think is a JH-63X... If you find 1 of those let me know...
Later
so with the coil overs you dont need the torsion bars right or am i wrong any way it look good.is that the beebani mount kit or did you make that your self.i love it though.
The torsion bars are all gone... Those are BeeBani brackets... They had to be adjusted a little higher because they were made for a 620, the 521 shock perches are a little shorter... They work great... Also, if you do get BeeBani brackets make sure when you buy coil overs you get the ones with bearings and not bushings... the bushings are a little wider than the bearings so we had to grind a little off... The brackets themselves are very strong and professionally made... I recommend them...
