winter warrior "elenor"
lol thats why i got it for winter driving and my all around vehicle yeah its only 2 wheel drive or 4 wheel drive no low range but that might get fixed in the future i also have 2 motors that come with it i have no idea what they are in terms of displacement or anything like that but i could trade parts or buy a bigger boxer motor later down the road for now im just gonna rock it how it sits maybe a slight lift
  • Replies 287
alright i got it home!!!!!!!
loading it
trying to get out
gave up and crawled out the passenger side which was no small task
whos tailgateing me... casper
destination reached
i have got to do something about the seats they sit to high and the steering wheel is in my crotch
unloaded the goodies
these may be all aluminum but damn there still heavy
next to michelle i looked at them side by side there is somthing wrong when my station wagon is 3 inches shorter then my 2 door coupe
so today we filled the radiator adjusted the carb and wired the fan to a toggle switch since the stock thermo switch is dead also fixed the temp gauge
all in all a good day
today was cleaning day i washed it cleaned out the interior scrubbed the engine bay cleaned up and painted the push bar the rims with the best tires on them started bleeding the brakes but when my sister prooved to be less then helpful at working the brake pedal i gave up ill try again later i also replaced all the vacuum lines going to the carb and put a new radiator cap on it so the cooling system will hold pressure
ignore the chunk of vacuum line on the seat
then i remembered i had the stock hubcaps from shelly and that they were 13's im glad i hung on to them
cleaner engine bay
well today after work my dad and i bled the brakes and i installed a tach now that i got to drive the car faster then 5 mph the speedo doesnt read past 20 and the clutch slips baaaaad but other then that its a solid car
im thinking i might go with a mild lift
this brat is stock
now its not lol
a mild lift would be cool but for the terrain around here a rally style setup would be best but then again its not winter yet so it might need a lift my biggest issue with lifting it is that its not actually lifting it its lowering the drive train so im not really getting more travel just ground clearance
2 things that "almost" every one fs up on lifting a roo
1 look at that camber! jumping and or hard wheeling is going to tare that thing apart pretty fn fast,
2 look at the oil pan, body lifts on subies should be done in mudderation. the oil pan is infrenging on the aproach angle, and believe me the crank twkes up alot of that space ive seen a dry sump done but it didnt gain much clearence for the effort
4 inches is great and with a little trimming can fit pretty big tires ( maybe a small castor ajustment) 2011-07-22062133.jpgoh and fitting a truck rim in side the fenders is hard so try looking at trailer rims
2011-07-22062201.jpg boggers make tsl's in 29 inch now, or do baja claw, or whatever
and you bolt in a 94 2.2 ltr ( the motor only has two plugs to wire up94 or new, older theres 3 or 4 plugs no biggie) and low range doest matter, the low range trans are abit stronger tho,
or skid plate it and get some studded snow tires and rock it. if you get hung up you just hold the gas down, slam the clutch in and slide your foot off the side repewdily while jerking the wheel back and forth with great vigor. they dont realy get "stuck" they just lose momentum
well i got a clutch for it and for free non the less! local subaru guy had it laying around i asked how much he wanted for it and he said free get it out of my life so for 200 bucks plus the cost of registration i have a 4x4 for the winter can we say winning? cause i can
