Building my first 510
  • Replies 163
  • 3 weeks later...
  • 2 weeks later...
  • 1 month later...
they look nice. They remind me of the batmobile. The mesh does get lost with the super fat lip color matched.
opinions? of course the bolts will be stainless steel, so that will add some contrast. not taking the time to pc or paint each one and not using oxide bolts.
Looking good by the way its refreshing to see another box flared getting a facelift. Is this a full track/race car?! Just a little puzled about removing the spare well. Your color choice is great the metallic flake will make those flares pop out. What are the spec on that motor?
This will be a street build with a hard suspension for some track days. the removal of the well was completely just due to taste for me. #1 It will never hold a spare for my setup. #2 I wanted to see the rear diff from behind the car and the coil overs. I really reinforced the area to make up for the loss of rigidity. 3 lengths of 1x3 square tube with 14 gauge steel plate. looks sorta clean and stock inside the trunk.
I agree about the webbing and when the wheels are PC'd and all together i will make a judgement call on maybe highlighting the top of the webbing's with another color.
the 2.4NAPZ is stock with port matching. running 44 Mikuni's on it and header. not the fastest engine. but simple and light. I just wanted torque, don't need to brag about my HP or top end.
  • 3 weeks later...
Anything above the 1.8 liter can run a supercharger and not have the parasitic drain affect the performance.
Well not anything but this z motor you have would be awesome on a centrifugal supercharger, easy to install, no extra exhaust tubing or inter cooler, no bov, and extra 5-8 lbs of boost. Fuck yes
  • 4 months later...
