fourfiveten Posted June 9, 2011 Report Share Posted June 9, 2011 Gotta love these forty year old cars. Can someone please put up a link to the GM alternator swap for 510, I've been looking and cant find it. Need it for tomorrow morn. so I can keep on to Canby on Fri. Please help, Thank you. Quote Link to comment
izzo Posted June 9, 2011 Report Share Posted June 9, 2011 http://community.ratsun.net/topic/21387-how-to-install-gm-105-amp-alternator/ Quote Link to comment
fourfiveten Posted June 9, 2011 Author Report Share Posted June 9, 2011 Thanks h2theizzo! Quote Link to comment
albyneau Posted June 9, 2011 Report Share Posted June 9, 2011 Thanks h2theizzo! Quick -n- speedy service~ with a smile... Hail to the Izzo! Quote Link to comment
fourfiveten Posted June 10, 2011 Author Report Share Posted June 10, 2011 OK got everything bolted up. Now the wiring question. GM alt swap says stock red/white to post. Done black wires to the gm plug wire??? my plug is generic with 4 wires plug wire 1( stator (ac) probably the air cond. plug not needed plug wire 2(ignition/lamp (+)) probably don't connect? plug wire 3(ignition(+)) connect black wires here? plug wire4 (sense) and in addition to the stock red/white wire and the stock black wire running to the posts on the hitachi alt. there is also a plug with a stock 16g white/black stripe wire and a stock 16g yellow wire. Where should these connect Quote Link to comment
banzai510(hainz) Posted June 11, 2011 Report Share Posted June 11, 2011 you look in the How TO section I think its there. i know you short out the old volt reg connector since your going to IR type alt. red/wht short to blk white and yellow shot to white i think the Dime Quarterly has it in the eleltrical secion on thow to short at least this part. The GM extra wires I knwo there were a couple connecter soem are 2 3 maybe even 4 wires Quote Link to comment
