620 drop.....
F.T.W
Hey guys, I have a '73 620, and of course I want to lower it. But I had a couple questions first.
Im wanting to go with a 4" drop, what kinda trouble am I going to run into with that amount? Also will the torsion bars be able to accomodate that much? I want to to look even all the way around, but I want it low.
I realize Im probably going to want to go through and freshen things up, like shocks and probably a carrier bearing. Anything else?
I can't really think of anything of anything else to ask right now...
Thanks in advance though!
  • Replies 5
Yeah, Im up here a ways.... it sucks.
What does reindex the torsion bars mean?? Yeah I figured I'd have to murder the bump stops, no worrys, its the same on my Rabbit truck too. haha
Guest DatsuNoob
Your rear axle will most likely hit the frame. I put 3" blocks in the rear, and mine hits everytime I go over a speed bump or anything like that. Although I haven't yet had the chance to trim the bump stops, Probably wouldn't help out a great deal. I'm still considering a mild notch for this reason. I have 1 ton springs though, not sure if that makes a difference.
  • 1 month later...
