HiComp ITB KA24DE 510
  • Replies 764
  • 3 weeks later...
Since i'm ALMOST done with my car, i think i should have list of my goals and cross them off as i go.
i think the toughest thing im going to have to do right now is put the gas tank in without cracking that plastic piece.
Note that i include long term goals i intend to do within 2 years
1. Moar lower
2. Carpet + interior
3. Convert to stick
4. get a good sound system without cutting holes or annihilating the interior, NO 15 inch subs for me, ok maybe one lol
5. Rebuild L16 bore to L18, and Turbo + EFI (Yes, i have the block)
i'll add more goals as they come. right now i have a basic understanding of what to do with the engine to make it L18ET
Oh and the L20b BARELY cleared the hood like maybe a eighth of an inch
Did you put a 510 oil pan on it before installing it? That (and occasionally slotting the engine bracket mounting holes) is usually what you need to get it lower. ;)
Did you put a 510 oil pan on it before installing it? That (and occasionally slotting the engine bracket mounting holes) is usually what you need to get it lower. wink.gif
yeah i switched the oilpan, but i didnt have to slot the bracket holes at all, the carbs air cleaner even clears!
Yeah!!!
this thing run yet?
If you have point distributor I dont see a Ballast resistor dor the POINT coil. If you have a Matchbox then make sure you have a EI coil.
I dont see the PVC hose hooked up to the crankcase
also the other hole below carb needs to be plugged.
Fuel pump is from a 620 which will work but the 510 ones have the inlet /outlet in the correct spot. to make it a cleaner run from the corner by the lights to the inlet of fuel pump.
this thing run yet?
not yet
i have the ballast resistor just haven't put it on
i cut the L20B tube and just need to get a hose
for the the hole you mean the only other one on the manifold besides the PCV valve?
yeah i was meaning to switch the fuel pumps out. i might as well get a new one though
uh Houston...
im not sure about the following..
bunch of wires that are supposed to go to ballast, dizzy, and coil
and also that dizzy pic is of what i think is supposed to be TDC
and those tubes on the intake, i know the one pointing to the firewall is PCV, and the rest idk lol
