B 210 motors?
NWOleman
  • Replies 15
L20B makes the B210 fly... for cheap. Bolts right in if you find the right crossmember (610?)
Yes, it's a "bolt-in" with a 610 crossmember. Those aren't too easy to find though. ;)
With a 510 oil pan and slightly modified 510 engine mounts, it's a good fit.
and use the B210 auto driveshaft.
I'm starting to think this is a myth. I've heard this many times, but my B210 auto sure looks like it has the small-spline input, not the larger L-series input. I'm swapping out the auto next week, so I'll know for sure then. :D
Not a myth. :P
I have a 610...when I attempted to install the L20 with the 510 oil pan and engine brackets/ mounts it would not sit on the chassis correctly...the pan would rub on the steering linkage and the steel brackets would not sit on the rubber mounts I had to use the 610 oil pan and engine brackets! So I don't know if things would be different with the B210 chassis.
If anything to avoid searching for a crossmember...cut off the stock brackets and weld you own mounts after you center the block and transmission to your liking on the crossmember! :cool:
Yes, 510 and 610 definitely don't mix and match. The sump is shaped differently on them. As is the 620 pan. Even though they all look kinda similar. :P
Since the 510 is the smallest sump of the 3, I would start there if you can't find a 610 crossmember.
