EastBay521 Posted October 18, 2015 Report Share Posted October 18, 2015 Does it smoke? No one likes a quitter Quote Link to comment
Draker Posted October 18, 2015 Report Share Posted October 18, 2015 Put it back!!!!!! Quote Link to comment
TENDRIL Posted October 18, 2015 Report Share Posted October 18, 2015 i might be pulling the trans also to un-fuck the drain plug fiassco i got down there........ but my car is too low and no jack stands....hmmmm Quote Link to comment
MicroMachinery Posted October 18, 2015 Author Report Share Posted October 18, 2015 Never too low. 1 Quote Link to comment
EastBay521 Posted October 18, 2015 Report Share Posted October 18, 2015 I can drop some off if you need. Ill be in the area later on 1 Quote Link to comment
TENDRIL Posted October 19, 2015 Report Share Posted October 19, 2015 found the culprit Quote Link to comment
TENDRIL Posted October 19, 2015 Report Share Posted October 19, 2015 oil control ring expander not expanding the rings evenly/ or at all really so it was like i had no oil control rings..... Quote Link to comment
TENDRIL Posted October 19, 2015 Report Share Posted October 19, 2015 new rings with functioning expander 1 Quote Link to comment
uberkevin Posted October 19, 2015 Report Share Posted October 19, 2015 Oh yeah?! Sweet. 1 Quote Link to comment
uberkevin Posted October 19, 2015 Report Share Posted October 19, 2015 new rings with functioning expander Quote Link to comment
Draker Posted October 19, 2015 Report Share Posted October 19, 2015 Why was it not expanding? Shit in the lands? Wrong rings? Shitty rings? 1 Quote Link to comment
TENDRIL Posted October 19, 2015 Report Share Posted October 19, 2015 well that's the part i don't want to say :sick: , it was because i fucked with the expander before hand..... its faint but i remember it not compressing in the ring compressor, so i nipped a groove off and it compressed, keep in mind i did not do this without first searching... well i read some bad info and made a costly mistake and hope this saves someone some time and money! 1 Quote Link to comment
Draker Posted October 19, 2015 Report Share Posted October 19, 2015 Whoops.. :) 1 Quote Link to comment
Draker Posted October 19, 2015 Report Share Posted October 19, 2015 The internet... full of bad info. Quote Link to comment
datzenmike Posted October 19, 2015 Report Share Posted October 19, 2015 The two oil control rings act like squeegees and other than they are thinner, are just like the other two top rings. That middle wavy part is called an expander in that it keeps the two rings equally spaced (expanded) apart from each other. It does not force the rings outward against the cylinder wall. That is a function of the diameter of the rings being larger than the bore and being compressed when installing. They should normally be free to move laterally against the bore. If those two thin oil control rings were jammed, it will almost certainly be that the ring land was damaged or the expander was damaged/faulty, or both. 1 Quote Link to comment
TENDRIL Posted October 19, 2015 Report Share Posted October 19, 2015 all ring end gaps were spot on with measuring closer to the tight end of the clearances, top, second and oil , on the old rings on all 4 cyls. everything moved freely, no damage to any of the rings or pistons soooo i dont know anymore if that will even fix the oil consumption .....thanks miike :poop: <_< but what i'm saying is the expander and the two thin rings could move any way they wanted, with fucked up expander, with new un fucked expander all three move as one ring essentially Quote Link to comment
Draker Posted October 19, 2015 Report Share Posted October 19, 2015 Check the clearance with the rings in the ring lands? Quote Link to comment
Amerikilla Posted January 16, 2017 Report Share Posted January 16, 2017 WHAT HAPPENED? Quote Link to comment
