Valentine
  • Please log in to reply
1536 replies to this topic
#1521 mrbigtanker
mrbigtanker
    Hall Monitor
  • Senior Member
  • 11,807 posts
  • Cars:Trailblazer ss/72 521/71 goon/454 SS/2016 canyon
Posted 24 December 2017 - 11:58 AM
One common complaint with pickup truck owners is vibration while loaded up. The pinion angle is set with no load in mind, because that's the most likely scenario. When the suspension compresses, the pinion angle shouldn't change much, but it does change.
If you really want to fix the problem, you can get creative with a two piece shaft and a CV on the middle joint (like Toyota). Any driveline shop should be able to make you a custom setup, but you will have to verify or possibly reset the pinion angle to get the proper geometry.
I built a 63 Nova a couple years ago that rode on air bags. Since the customer wanted to be able to drive it at varying ride heights, we used a custom CV slip yoke on his driveshaft. No vibrations at all. I also use CVs on all of my offroad builds. It's just one of those details that gets overlooked by a lot of people.
These trucks come stock with a 2 piece drive shaft. I think he converted to 1 piece out of a 520, plus dropping does not help either. Its fixed now, just had to unload the bike. Merry Christmas.
#1522 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,001 posts
Posted 24 December 2017 - 01:11 PM
To fix this issue he could put small overload type airbags in the rear and when he loads it up put a little air in them till it has the proper stance.
#1523 skyblue
skyblue
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,689 posts
  • Cars:1971 510 4dr, 1972 521, 1966 Impala, 1966 Yamaha Campus 60(YJ2), 1973 240z, 2003 SV650
Posted 26 December 2017 - 02:55 PM
thats's a good idea.
I tried to install some air shocks a while ago, but they were too fat and would not clear the shock cross member. Maybe I'll do like jrock and relocate that cross member ti clear air shocks.
#1524 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,001 posts
Posted 26 December 2017 - 05:19 PM
So you are saying that when you tried to mount the air shock on the upper mount(eye type mount) the hood/sleeve of the shock hit the cross member the mounts are connected to?
Can you buy a lighter duty air shock that is not as large.
#1525 skyblue
skyblue
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,689 posts
Posted 26 December 2017 - 07:36 PM
That is correct.
At the time they where just some shocks busta nut had. a lighter duty shock is a good idea, ill have to look into it.
took her out shopping and stopped at in n out for lunch.
#1526 mrbigtanker
mrbigtanker
    Hall Monitor
  • Senior Member
  • 11,807 posts
Posted 26 December 2017 - 08:33 PM
4x4 ketchup mustard and extra cheese. 2 fries. Oh and nice truck.
#1527 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,001 posts
Posted 26 December 2017 - 09:33 PM
I have bolted hijackers onto my 521 without any issues other than they rubbed on something(I don't recall now), they lasted for several years, after they rubbed thru I replaced them with some coil over shocks and I installed the overload air bags, when I had the hijackers I still had the stock bed floor.
#1528 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,184 posts
  • Cars:1966 520, 1985 720 ST King Cab, 1986 720 King Cab
Posted 10 January 2018 - 09:27 AM
Quit carrying heavy loads!  LOL
#1529 banzai510(hainz)
banzai510(hainz)
    L motor God
  • Senior Member
  • 15,060 posts
Posted 10 January 2018 - 01:21 PM
I love that blue truck  esp the wheel set up,lowered
Throw on some Weber sidedrafts, Rising Sun hood.... call it good
#1530 skyblue
skyblue
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,689 posts
Posted 11 January 2018 - 06:35 PM
Lol.
Thanks!
#1531 mrbigtanker
mrbigtanker
    Hall Monitor
  • Senior Member
  • 11,807 posts
Posted 11 January 2018 - 07:54 PM
I love him he makes great drinks.
#1532 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 3,904 posts
  • Cars:http://www.4wdandsportutility.com/features/rover/0611_4wd_1957_range_rover/viewall.html
Posted 12 January 2018 - 08:57 AM
Yeah, but it's a truck!
#1533 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,001 posts
Posted 12 January 2018 - 09:55 AM
Does this truck have 4X4 leafs on it?
I went back a few pages, but the photos are gone so I gave up looking and decided to ask.
#1534 skyblue
skyblue
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,689 posts
Posted 12 January 2018 - 05:56 PM
my thoughts exactly. lol
It does. new shocks all around too.
#1535 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,001 posts
Posted 12 January 2018 - 07:54 PM
So I went back a page and noticed something, you have the 2 piece drive shaft in it right now?
If you do look at the rubber piece that is bolted to the cross member at the carrier, if the rubber is deteriorating and the drive line can move to the side it could possibly start rubbing on the housing that holds the rubber piece in, that would make a metal to metal squeaking sound, and since the truck is lowered, the drive line itself might not know where it wants to be, it might not have squeaked at first till it settled into the position that caused it to squeak.
Also you might look at the drive line yoke going into the transmission, when lowered does the drive line compress all the way and force the front drive line piece/yoke farther into the transmission and maybe bottom it out, and the squeak was the yoke outside dust sheild either being forced to the side and rubbing the side of the tail shaft, or maybe the yoke is just being pushed to far into the transmission and the yoke inside is rubbing on the end of the tail shaft that holds the seal.
#1536 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,184 posts
Posted 12 January 2018 - 09:20 PM
Then do not whine when you put heavy loads in a lowered truck!!!  LOL
What size blocks re in the back?
Do you have much suspension movement front and back before hitting stops.
Measure your rear bed hieghth empty and then load your bike and measure again.
Also wuth the bike loaded look under the truck at the drive line and the bump stops if you have any.
Measure the axlehousing to frame clearance loaded.
This is one of my favorite 521s so please do not "fuck it up"!!!  LOL
#1537 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 3,904 posts
Posted 13 January 2018 - 09:45 AM
We can try to make them better though. It doesn't have to suck.
