Valentine
skyblue
  • Replies 1.6k
Man.. I need to tire up one of those..
It's super easy. Took ME a bit cause wiring is not my forté. But once I figured it out I was like, " that wasn't so hard." Lol
kidding about canopy dude ... sheesh ... nice on the cig wiring
oh. Lol. You got me.
I did the 720 4x4 leaf swap to my 521 today.
Here's what I learned.
The leafs:
5AB25BC6-DA09-4F18-8FD5-35302CAA4F30_zps
The shackles:
For the 521 use the 521 shackles.
The bushings:
I replaced the top shackle bushing with whiteline W73252. http://www.whitelinesuspensionparts.com/w73252
AE5D0262-A13A-4541-9466-C94888EE823A_zps
21626CC7-B867-42F0-A65D-0BA3BC731B7E_zps
When I bought the leafs it had poly bushings which I thought were correct for the lower shackle bushing.
F98C9BF5-B493-4BAA-8A28-9BEC66215AD4_zps
But I was wrong. The O.D. was right. But the I.D. was waay to small. I think these bushings are for 720 or 620.
So I reused the 521 bushing until I can find a replacement or drill out the poly ones.
Then there's the front eye bushing. The poly bushing that came with the 720 4x4 leafs was also wrong. The O.D. was correct, but the I.D. was too big for the 521 bolt. Or it's missing a sleeve. Anyone know if you can get just sleeves? Or Again I think this bushing is for 720 or 620.
743C7158-8422-4919-BA7B-5725FB09811E_zps
I ended up using the poly bushing for the front eye because the 521 bushing looks like it was pressed in and there was no way I was gonna get that out. Gonna use the poly until i get the ones I ordered. Which I hope are correct and that they come soon. with canby closing in the loose bushing sketches me out.
I ordered Whitline W71055 http://www.whitelinesuspensionparts.com/w71055_rear
Progress pics
59E1B54F-C5CF-4555-8803-B8C4E7616407_zps
521 on top 720 4x4 on bottom
743BD0CA-B79B-4519-91AA-ECF263AC75BD_zps
Done
943B8776-6ADA-487F-A2F1-DDBCD839E5CE_zps
4381AEB1-0B85-43CC-B27D-28127EE888DE_zps
I will also say I'm using 3 in. Blocks
Anyone need stock 521 leaf packs?
46E6ADC7-95D5-4587-84B3-F6C242B038C5_zps
And spacers?
680CE9EE-D6F7-4184-AFF6-43CF98A39ED3_zps
  • Like 6
Well, not really. The rebuild kits I got were both the wrong size. Gadamit!
So I just cleaned everything and slapped it back together. Truck stops. Not the best but stops. Still leaks. I ordered some wheel cylinders that I should get before we leave for canby.
Just changed the oil. Played with drilled out poly bushings with zero succes.
Drilled out some poly bushings but they did not fit.
B52853D0-2088-4A9F-B479-80317D32F9AD_zps
Rear Shocks are shot so played around with what we had. Bustas old air shocks. Too fat.
709F840D-AB97-4BFA-A205-B988288D5CB0_zps
510 shocks. In case anyone else was wondering. They're too long.
2A03E75D-ACAB-4033-9BF4-6E8765F6078C_zps
Kingpin swap
6B8E05D5-2228-4706-A40B-8437B7896B8D_zps
Old upper bushings.
D1E7ED1F-A073-4E5B-B20A-BB2EF309EA5E_zps
New bushings
C83EAFFD-E112-4BD0-8366-92ADA1B36A9F_zps
Seals cleaned
346387F9-4CE2-4F54-813F-47CBB5B375A5_zps
Good as new. One side done
34AC53E2-22FE-46D3-A53D-AEDD4567D443_zps
  • Like 6
