koyoteracing Posted January 25, 2011 Report Share Posted January 25, 2011 Ok guys these is a treasure found its a crate L18 engine and it a new or remanufature engine am not sure but every were i see its looks brand new and i dont want to wore it out on ebay or craigslist it needs a nice home 800$ shoud be fair !!!!!! Link to comment
DISLEXICDIME Posted January 25, 2011 Report Share Posted January 25, 2011 Are all of the intake port eye browed like that? Link to comment
tdaaj Posted January 25, 2011 Report Share Posted January 25, 2011 could be fi head uh? Link to comment
Just Joel Posted January 25, 2011 Report Share Posted January 25, 2011 nice, wish you were closer... later joel Link to comment
hobbes_the_cat Posted January 25, 2011 Report Share Posted January 25, 2011 could it be an old 30k japan import motor? that would be more likely to have a FI head. how did you come to own it? Link to comment
koyoteracing Posted January 25, 2011 Author Report Share Posted January 25, 2011 they all look like that !!!! Are all of the intake port eye browed like that? Link to comment
tdaaj Posted January 25, 2011 Report Share Posted January 25, 2011 looks kinda off though, i don't remember freeze plugs being painted, and the valve cover looks painted also, along with the head. even low milage engines had a smidge of dirt on them. Link to comment
koyoteracing Posted January 25, 2011 Author Report Share Posted January 25, 2011 these engine has not been fire you can clearly tell from the ports and i saw inside the spark plug hole and ist new inside just could not take a picture but ists new !! Link to comment
datsunaholic Posted January 25, 2011 Report Share Posted January 25, 2011 That looks very much like a brand-new engine. That or someone took a great deal of time to make it look that way. Link to comment
tdaaj Posted January 25, 2011 Report Share Posted January 25, 2011 well then $800 might be a good deal Link to comment
koyoteracing Posted January 25, 2011 Author Report Share Posted January 25, 2011 its all like that every were you look is new !just been store for a some time !!!! Link to comment
erichwaslike Posted January 25, 2011 Report Share Posted January 25, 2011 the tape on the end of the crank shows its never been put infront of a manual, looks like something to cover grease for the pilot? looks like something nissan wood do, not so much an engine builder Link to comment
SSS510 Posted January 25, 2011 Report Share Posted January 25, 2011 could be fi head uh? Certainly looks like it! This would be great for someone looking to do FI set up... NICE GLWS!! Link to comment
banzai510(hainz) Posted January 25, 2011 Report Share Posted January 25, 2011 Looks like a rebuild from Thailand. from back in the 90s unless there is a Nissan or Bap Geon (GoldStar) labol that tells somthing else. I had a Thailand rebuild. Back in the day they were about 500-800$ or so. Nissan had a clearance also in the 90s with crate motors. but about $900 or more. the notces are for the injectors. so be a good choice for a FI conversion maybe somebody on the 510realm might want this also My Thailand rebuild lasted 50k miles. Its started stinking.(blowby) when I opened the motor ever bore had a ring land scare in the same clocking position so I assume they gapped the rings wrong. My Jap Bap Geon rebuilt lasted 60kmiles . The head gasket was leaky. When I tore it apart I notice the head bolts loose. but proceeded to remove the head. Gasket looked fine so I guess all i needed to do was torq the headbolts down and that would have been it. But I notice the exhaust valve was running out of adjustment(valve lash) and woud have needed to get pulled soon anyways Link to comment
racerx Posted January 25, 2011 Report Share Posted January 25, 2011 what part of Cali are you from and where did you pick this up from? Link to comment
fisch Posted January 25, 2011 Report Share Posted January 25, 2011 THis is really cool man. Indeed! GLWS Link to comment
koyoteracing Posted January 25, 2011 Author Report Share Posted January 25, 2011 im in azusa california and i got it from a nissan dealer that closed down and they hade a bunch of parts for sale they aso hade a skyline engine and some other parts what part of Cali are you from and where did you pick this up from? Link to comment
RoadRace Posted January 26, 2011 Report Share Posted January 26, 2011 Looks like a rebuild from Thailand. from back in the 90s unless there is a Nissan or Bap Geon (GoldStar) labol that tells somthing else. I had a Thailand rebuild. Back in the day they were about 500-800$ or so. Nissan had a clearance also in the 90s with crate motors. but about $900 or more. the notces are for the injectors. so be a good choice for a FI conversion maybe somebody on the 510realm might want this also My Thailand rebuild lasted 50k miles. Its started stinking.(blowby) when I opened the motor ever bore had a ring land scare in the same clocking position so I assume they gapped the rings wrong. My Jap Bap Geon rebuilt lasted 60kmiles . The head gasket was leaky. When I tore it apart I notice the head bolts loose. but proceeded to remove the head. Gasket looked fine so I guess all i needed to do was torq the headbolts down and that would have been it. But I notice the exhaust valve was running out of adjustment(valve lash) and woud have needed to get pulled soon anyways good info Hainz. FYI: there was a motor like this on ebay last year - painted light grey, all new L18 and it went for $200. Link to comment
Jester Posted January 26, 2011 Report Share Posted January 26, 2011 im in azusa california and i got it from a nissan dealer that closed down and they hade a bunch of parts for sale they aso hade a skyline engine and some other parts What......No pictures of the Skyline engine??? Link to comment
Focus Posted February 7, 2013 Report Share Posted February 7, 2013 I just came accross the same type of crate engine L18 same color block, A87 head (no notches) block #5417B N68, but mine has a Gold Star remanufacterd in Japan for Bap Geon sticker on it. It has a sticker on it that says to torque head to proper spec's then again once at operating temp. My question, should I just replace the head gasket to be on the safe side or just do what it says above. I came across this engine as a estate sale and the seller said it had been stored for over 20 years. Does anyone know anything about Gold Star ? I am not sure if I want to install it or just save it. Link to comment
Focus Posted February 16, 2013 Report Share Posted February 16, 2013 anyone ? any info ? Link to comment
