New one
Peter_Pablo
Well my name is Peter Varela and i´m from (sonora mexico) near to arizona, and i just bought a 620 truck around 6 months ago. so i take it because i love this trucks and I try to buy one since 2006 but i couldnt find anyone in good shape so finally I saw one in other city and tell the owner if he want to sell it and he say yes,, so here I am :D
so this my truck when i bought it
rear wheels 10"
next mod, low 2" front and rear 4"
then put led in side markers
and results is....
and rims arrived
original color don't like to much so i decided to painted graphite color
front suspension arms
  • Replies 160
the next step swap engine
that is supost it have
but the reality is other and older L16 (96hp)
the new one is ka24e (134hp) hardbody
removed engine L16 and clean
painting white
and then the ka24e
so i don't have arnes and ecu i decided put a carb (ford 2 throats)
finally
I hope you like this project
I liked the unpainted slotted mags. The graphite color on the others is way better.
The KA uses a crank angle sensor for a distributor. This info, plus all the other EFI sensors are used by the ECU to determine when to fire the plugs and the spark advance. I don't know how you will solve this problem but good luck and let us know. A carb KA should go alright.
im join to yours with the ratsun sticker, but with a slight modificacion because here in my town there a serious problem with the letter X as an armed people bring it and put a "X" sticker on the glasses and the truth can not be brought because you get in trouble and is the reason to change it a bit to avoid problems i hope you understand smile.gif
que onda bato, soy de Tijuana me llamo Jose, de que parte de Sonora eres?
Va quedando bien la camioneta, yo llevo rato queriendo meterle esos rines en 5 rayos.
soy de altar sonora y así si es a mi también me gustan los de 5 aspas pero salieron estos de oportunidad y los aproveche y pos ya lo que sigue es la carroceria y partes para que ya tome forma la nave. saludos a tijuana por ahi anduve el mes pasado buscando motor pal datsun jeje pero salio uno en mexicali y me regrese por el y es el que traigo ahorita thumbup1.gif
well I decide to put leds in the brakes lights and that´s the work
the next steps is to buy the tailights because as you know everything is older in this car jajaja so I need step by step doing my thing to can put it up again
tomorrow put how is it look like in the night because i cant take it for another think to do
and just in the morning of this day bought this 620 (in 250dlls also runs good) it´s for use the front suspension because my 620 its to damage
I will use the front bumper its in good shape and the grill because really like a lot and i dont know what else dry.gif
well i stared to change the bumper
orale no avia visto el tema pues ai la llevas al cien y rapido va kedando mui bien como jala con el ka ?
quedaron mui bien los rines, arregla el caja corta ......
asi es pero tiene mas chamba ese aunque no lo creas que el long bed y la neta ya me gusto mas que el cortito y la neta jala bastante desente solo que necesito cambiar el diferencial para que ya quede la relacion que lleva del hardbody y segun cuentas llevo un mes y 8 dias para ser exactos con el proyectin esperemos y quede mas o menos como lo tenemos planeado thumbup.gif
que chingon, yo voy mucho pa el sur, voy a los mochis, conosco altar nomas de pasada, haber si me toca ver la troca en una de estas idas, va quedando bien la camioneta, yo tenia esta idea de ponerle leds, pero la ando calando en mi otra camioneta, me concegi unos leds ultra brigth y ando haciendo la placa del circuito para que entre directo en la ploga del foco original,
pues puede que lo veas de pasadita vivo cerca de la iglesia a una cuadra y ahi esta el general lee laugh.gif o de perdis un vasito de agua que no se le niega a nadie
  • 3 weeks later...
