RAlly_DatoB210 Posted December 23, 2010 Report Share Posted December 23, 2010 The other day I tried to run some seven or eight inch wide progressive rims with -25 offset and they poked out a good inch or more and rubbed like hell on the fenderwells at the slightest bump or turn. Stock ride hight and about a cm of clearance tires were 205 60 r13 what is the widest rims you can tuck? I have ran it with 14 in z turbines and huge snow tires and they didn't have a clearance issue haven't driven it though. What does every one here run? The slotted mags are a nice fitment Quote Link to comment
Wood Posted December 23, 2010 Report Share Posted December 23, 2010 I run 15X8 -63, hacked fenders. it rubs on bumps and wide turns :) Quote Link to comment
RAlly_DatoB210 Posted December 23, 2010 Author Report Share Posted December 23, 2010 I don't want to hack mine up. Too clean and rust free of body but I think it would look good slammed with vg flares. Just don't want to smoke wrench it Quote Link to comment
RAlly_DatoB210 Posted December 28, 2010 Author Report Share Posted December 28, 2010 These rims will work for someone else trade for another set I can drive around on? Quote Link to comment
datsunfreak Posted January 15, 2011 Report Share Posted January 15, 2011 Offset is the key thing. With a mild fender roll you can easily run a 14x7 (with 185/60-14 tire) or 15x7 (with 195/50-15 tire) zero offset wheel. Without serious hacking, that is about as stout as you can go. I am currently running a 14x7 -9 with a fairly stout fender pull/roll. Quote Link to comment
Burabuda Posted January 16, 2011 Report Share Posted January 16, 2011 do the zx struts and that gains you some more clearance for the fronts Quote Link to comment
datsunfreak Posted January 17, 2011 Report Share Posted January 17, 2011 do the zx struts and that gains you some more clearance for the fronts Yes, but most 13" wheels don't clear ZX brakes. ;) Quote Link to comment
