RockAuto 411 parts closeout
MikeRL411
RockAuto Catalog Wholesale Closeout Part Listings : 1967 NISSAN 411 1.6L 1595cc L4 [R16] <http://www.rockauto.com/RSS/images/feed_icon.gif>
Brake/Wheel Hub
Part Type: Brake Pad
<http://info.rockauto.com/getimage/getimage.php?imagekey=490081&imageurl=http%3A%2F%2Finfo.rockauto.com%2FBeckArnley%2FBA%25200820118-1.jpg>
* Manufacturer: BECK/ARNLEY
* Part No: 0820118
* Notes: Thru 8/68; Original Equipment Pad Material; Front
Regular Price: $15.02
Closeout Price: $6.55
SAVE 56%
Only 4 Remaining!
<http://www.rockauto.com/RSS/images/en/goToTheCatalog.gif>
Part Type: Wheel Cylinder Repair Kit
<http://info.rockauto.com/getimage/getimage.php?imagekey=314502&imageurl=http%3A%2F%2Finfo.rockauto.com%2FRaybestos%2FWK608-1.jpg>
* Manufacturer: RAYBESTOS
* Part No: WK608
* Notes: Rear
Regular Price: $8.34
Closeout Price: $4.31
SAVE 48%
Only 12 Remaining!
Cooling System
Part Type: Thermostat
<http://info.rockauto.com/getimage/getimage.php?imagekey=481835&imageurl=http%3A%2F%2Finfo.rockauto.com%2FBeckArnley%2F1435686.jpg>
* Part No: 1435686
* Notes: [Thermostat]; 192 Degree;Fail-Safe;
Closeout Price: $5.93
Part Type: Thermostat Housing Gasket
<http://info.rockauto.com/getimage/getimage.php?imagekey=476980&imageurl=http%3A%2F%2Finfo.rockauto.com%2FBeckArnley%2FBA%25200390004-1.jpg>
* Part No: 0390004
Regular Price: $0.57
Closeout Price: $0.29
SAVE 49%
Only 13 Remaining!
Electrical
Part Type: Alternator / Generator Brush
<http://info.rockauto.com/getimage/getimage.php?imagekey=47577&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FJX99_FULL.jpg>
* Manufacturer: STANDARD MOTOR PRODUCTS
* Part No: JX99
Closeout Price: $0.79
Only 2 Remaining!
Part Type: Alternator / Generator Rectifier
<http://info.rockauto.com/getimage/getimage.php?imagekey=50597&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FD12_FULL.jpg>
* Part No: D12
Closeout Price: $14.20
Only 1 Remaining!
Part Type: Battery Cable
* Part No: A484U
* Notes: Battery To Switch
Regular Price: $14.61
Closeout Price: $6.00
SAVE 59%
Only 6 Remaining!
Part Type: Starter Drive
<http://info.rockauto.com/getimage/getimage.php?imagekey=42326&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FSDN153_FULL.jpg>
* Part No: SDN153
Closeout Price: $13.23
Only 3 Remaining!
Electrical-Switch & Relay
Part Type: Oil Pressure Switch
<http://info.rockauto.com/getimage/getimage.php?imagekey=44248&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FPS202_FULL.jpg>
* Part No: PS202
* Notes: WITH GAUGE
Closeout Price: $18.12
Only 2 Remaining!
Emission
Part Type: PCV Valve
<http://info.rockauto.com/getimage/getimage.php?imagekey=50431&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FV184_FULL.jpg>
* Part No: V184
Regular Price: $2.75
Closeout Price: $1.42
SAVE 48%
Only 7 Remaining!
Engine
Part Type: Oil Filter
<http://info.rockauto.com/getimage/getimage.php?imagekey=56460&imageurl=http%3A%2F%2Finfo.rockauto.com%2FHoneywell%2FPH3639_012406.jpg>
* Manufacturer: FRAM
* Part No: PH3639
Closeout Price: $2.83
Part Type: Timing Chain
* Part No: 0240218
* Notes: [Timing Chain];
Closeout Price: $6.29
Only 15 Remaining!
Part Type: Timing Cover Seal
<http://info.rockauto.com/getimage/getimage.php?imagekey=253667&imageurl=http%3A%2F%2Finfo.rockauto.com%2FBCA%2FSEAL_32_ANG.jpg>
* Manufacturer: NATIONAL
* Part No: 224560
Regular Price: $3.83
Closeout Price: $2.01
SAVE 48%
Only 1 Remaining!
Ignition
Part Type: Condenser
* Part No: JC34T
Regular Price: $3.50
Closeout Price: $0.67
SAVE 81%
Only 3 Remaining!
<http://info.rockauto.com/getimage/getimage.php?imagekey=49583&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FJC34_FULL.jpg>
* Part No: JC34
Regular Price: $3.67
Closeout Price: $1.90
SAVE 48%
Only 6 Remaining!
Part Type: Distributor Cap
* Part No: JH59T
* Notes: Exhaust stock and reorder
Regular Price: $2.24
Closeout Price: $1.17
SAVE 48%
Only 4 Remaining!
* Part No: JH110T
Regular Price: $5.85
Closeout Price: $1.45
SAVE 75%
Only 1 Remaining!
<http://info.rockauto.com/getimage/getimage.php?imagekey=43413&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FJH-59_BOTTOM.jpg>
* Part No: JH59
Closeout Price: $3.66
Only 7 Remaining!
<http://info.rockauto.com/getimage/getimage.php?imagekey=43260&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FJH110_FULL.jpg>
* Part No: JH110
Closeout Price: $5.02
Only 11 Remaining!
Part Type: Distributor Rotor
* Part No: JR72T
Regular Price: $1.46
Closeout Price: $0.76
SAVE 48%
Only 15 Remaining!
<http://info.rockauto.com/getimage/getimage.php?imagekey=46494&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FJR72_FULL.jpg>
* Part No: JR72
Closeout Price: $1.46
Part Type: Ignition Breaker Points
* Part No: JP6T
* Notes: Points Set Only;
Regular Price: $1.09
Closeout Price: $0.56
SAVE 49%
Only 4 Remaining!
<http://info.rockauto.com/getimage/getimage.php?imagekey=49636&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FJP6_FULL.jpg>
* Part No: JP6
Regular Price: $1.50
Closeout Price: $0.77
SAVE 49%
Only 10 Remaining!
Part Type: Ignition Coil
<http://info.rockauto.com/getimage/getimage.php?imagekey=47803&imageurl=http%3A%2F%2Finfo.rockauto.com%2FSMP%2FUF2_FULL.jpg>
* Part No: UF2
* Notes: w/ External Resistor;
Regular Price: $37.79
Closeout Price: $19.88
SAVE 47%
Only 1 Remaining!
Transmission-Automatic
Part Type: Filter
<http://info.rockauto.com/getimage/getimage.php?imagekey=55891&imageurl=http%3A%2F%2Finfo.rockauto.com%2FHoneywell%2FFT1044_031006.jpg>
* Part No: FT1044
* Notes: Use until inventory is depleted
Regular Price: $11.59
Closeout Price: $6.03
SAVE 48%
Only 2 Remaining!
<http://www.rockauto.com/Images/ylwCrvLwrLft.gif>
  • Replies 4
Great information. Thank you. Is there a way to search on Rockauto for just the closeout items like you have it listed or do you have to look at each item?
If you log into their site and designate what models you are interested in [or just order parts for] you will get automatic closeout notifications. I also got 240SX closeouts but didn't post them.
