MicroMachinery Posted November 4, 2010 Report Share Posted November 4, 2010 Does anybody know anyone who has swapped a KA24DE into a 720 4x4? I'm playing with the idea of possibly doing this. Thanks! Quote Link to comment
izzo Posted November 4, 2010 Report Share Posted November 4, 2010 Micro, i was thinking about this some time back when i had that KADE and 85 4x4. Make sure its a truck KA so it has the oil pump like the L series and not built into the front cover, also you will need an oil pan off a KA hardbody 4x4 for front diff clearance. Motor will bolt up to existing trans. You will probably need a higher output fuel pump, then wire in the couple of wires. Off you go. That was the information i received when asking around some time back. Quote Link to comment
inda bebe Posted November 16, 2010 Report Share Posted November 16, 2010 would a ka24e 4x4 work w/ a 2wd 720? OR would a ka24e from a 240sx fit in the 720, but swapping the oil pan from a truck ka24e? its much easier finding the engine from the 240 Quote Link to comment
MicroMachinery Posted November 17, 2010 Author Report Share Posted November 17, 2010 From what I've read, the ka24e truck engine has a rear sump, while the 240sx version has a front sump. If you swapped pans from a 240sx ka24e, don't forget that you would also have to swap the oil pickup tube. I don't see why a 4x4 ka24e wouldn't go into a 2wd 720. Do a little snooping around here using the "search" function. People have done/are in the process of doing this swap. Quote Link to comment
Jester Posted November 24, 2010 Report Share Posted November 24, 2010 Not only do I think you should do it, I think you should do a FULL account, RIGHT HERE, on how it goes. I would LOVE to build a '86 KC, solid axle with a KA24DE. THAT would be the shiz! Quote Link to comment
datzenmike Posted November 24, 2010 Report Share Posted November 24, 2010 Whatever motor you use it will have to be shaped to clear the front differential. The 720 and D-21s aren't identical but it's reasonable to assume that the KA pan from a 4X4 would likely clear a 720 4X4 diff. It will take a lot more than a high output fuel pump to make this work. The KA is a fuel injected motor. The EFI wiring on the Hardbody is blended into the truck wire harness while the 240sx one is separate and easily removed. The 240sx intake is also better than the truck one. You need a high pressure fuel pump. Use an ECU from an automatic 240sx as this avoids the built in rev limiter on the standards. Quote Link to comment
izzo Posted November 24, 2010 Report Share Posted November 24, 2010 Whatever motor you use it will have to be shaped to clear the front differential. The 720 and D-21s aren't identical but it's reasonable to assume that the KA pan from a 4X4 would likely clear a 720 4X4 diff. It will take a lot more than a high output fuel pump to make this work. The KA is a fuel injected motor. The EFI wiring on the Hardbody is blended into the truck wire harness while the 240sx one is separate and easily removed. The 240sx intake is also better than the truck one. You need a high pressure fuel pump. Use an ECU from an automatic 240sx as this avoids the built in rev limiter on the standards. Mike, an added bonus. He bought my 80 720 4x4 :D But i gave him an L20 4x4 oil pan for the 80, so it might work? Quote Link to comment
