Subie Rear end installed
vegas510
Finally finished the rear end today. Started off with a 05 STI LSD rear diff, from ebay Ordered new wheel bearings and seals from Datsport. Got the stub axles from Beta motorsports. and Finally the Axles are from Wolf creek racing! I hope you guys like this set up, it seems pretty solid.
Stub axles with D bolts had to order the bolts from nissan.
Stub axles installed
Axles
Final result
  • Replies 9
Axles
Final result
fixed pics
  • 3 weeks later...
  • 3 months later...
Dude $125 for a WRX diff is a steal. You can use the Beta Motorsports stub axles which are pricey I think $500 for the pair, but you can use you stock 510 axles. But if your a baller like this guy CV axles are the way to go.
From what I have read stock axils won't work with any non clutch diff. The 2002 rear end has a different number of splints then the 510's soyou have to do an axil modification to make it work. Someone correct me if I'm wrong please!
Read the above by DREWSDIME... Tha Beta Motorsports stub axles are made so you can use the later 29 spline subbie rear ends and I believe that the 05 and later subbie rear ends are a clutch type LSD and not a VLSD
  • 3 years later...
