l series cams
jack
  • Replies 3
L20 cam is a bit more aggressive than a stock L16, tho not terribly much. It would be worth the swap. I think you could get away with using your stock cam gear, if not get the cam gear from the L20 head... (in fact, get it just in case. mark where it comes from and install same order you pull it out.)
