Porche 930 Cv adapters
V8Dat
  • Replies 7
On the other end we already had an adapter to run 280zxT axles and the Porsche fit right in those adapters. Just have to re-drill the Porsche bolt pattern. I'll post more pics as soon as i have the complete mock-up done.
its been a while since I have been under my Z but is this the diff side? Or is this the stub axle side because it looks like it could be either one. I have been dreading pulling my stub axles for the cv conversion but its got to be done if I want to run the VLSD. peace.
It's the diff side. I already have the outer stub axle side on the car. Will take pcs when I get done so you can see. Have to send these off now to the heat treaters. The material is 4130 CM. So after the Treatment, should be pretty strong.
