racerdad Posted January 10, 2008 Report Share Posted January 10, 2008 Anyone, will it work? Thanks, Darrel Quote Link to comment
Bleach Posted January 10, 2008 Report Share Posted January 10, 2008 it bolts up to the engine. The transmission mount is slightly further back. (1"?) Driveshaft splines are not a Nissan type. You will need the turbo 280ZX driveshaft and have that mated to your other Datsun driveshaft. Quote Link to comment
69FJWagon Posted January 11, 2008 Report Share Posted January 11, 2008 it bolts up to the engine. The transmission mount is slightly further back. (1"?) Driveshaft splines are not a Nissan type. You will need the turbo 280ZX driveshaft and have that mated to your other Datsun driveshaft. Are you sure about the splines on the drive shaft? cause Brandon (Fineline) has that tranny in his 620 and is using a Datsun driveshaft out of a 620 with the 12" front half from a automatic 620 or late long tail 5 speed,I think :confused: Quote Link to comment
Bleach Posted January 11, 2008 Report Share Posted January 11, 2008 I know the non-turbo 280ZX driveshaft does not fit the T5 tranny. I know the non-turbo tranny does fit the factory 620 driveshaft. I also remember Fineline put the T5 in his truck maybe he will find this thread and post specifics on what he did for the install. Quote Link to comment
Mark_Z28 Posted January 24, 2008 Report Share Posted January 24, 2008 I have both trans and can tell you for sure 100% that the regular non turbo yoke will not ever work on a T5 trans. Quote Link to comment
