BEEBANI Posted September 29, 2010 Report Share Posted September 29, 2010 Parts Needed: Rear Rotors, calipers, pads, and lines: 1989-1993 Isuzu amigo, 1988-1991 Isuzu Trooper, 1988-1995 Isuzu Pickup Instructions: Rear: 1. Remove Wheels 2. Remove drums 3. Remove parking brake cables 4. Remove brake lines from wheel cylinders 5. Remove 4 nuts behind backing plate assembly 6. Remove axle assembly (be sure to keep track of preload shims) 7. Remove the 4 studs (be sure no to damage the threads as you are going to re-use these) 8. The backing plate should be able to slide off the bearing housing to give you a better angle at your next step. 9. Remove backing plate. You have two ways of doing this. You can either have a machine shop remove the bearing assembly the “book” way or you can cut the backing plate off. If you choose the later be sure to protect the bearing assembly from the metal shavings you will create during the procedure. 10. Install the studs back in the bearing housing 11. Install axle back into axle tube with bearing spacer shims 12. Place caliper mounting bracket on the back side of the axle tube with the caliper position toward the rear of the vehicle and replace nuts removed in step 5 13. Slide rotor over axle 14. Install caliper mounting bracket using supplied spacers 15. Install calipers and pads 16. Install Isuzu rubber brake lines with banjo bolts and connect other end to existing hard lines These come with the caliper mounting hardware, and they are painted. The set sells for $150 shipped in the US. The stock e-brake cable will have to be lengthened, but these calipers do have a built in e-brake lever. 1 Link to comment
toyorotor Posted September 29, 2010 Report Share Posted September 29, 2010 Whats your paypal acct# ? Link to comment
BEEBANI Posted September 30, 2010 Author Report Share Posted September 30, 2010 pm sent Link to comment
Nissan_Boy85 Posted November 12, 2010 Report Share Posted November 12, 2010 Are these the brackets that will work for a 720 rear disc brake conversion? If so, will it fit in a 14" wheel? 1 Link to comment
Z-train Posted November 12, 2010 Report Share Posted November 12, 2010 will it fit in a 14" wheel? Yep,my question also. Link to comment
BEEBANI Posted November 13, 2010 Author Report Share Posted November 13, 2010 I'm not sure, the trooper's came stock with 15" wheels, but the rotor is very small in diameter, smaller than the stock 720 rotor 1 Link to comment
mklotz70 Posted November 13, 2010 Report Share Posted November 13, 2010 I originally figured this setup out. I'm pretty sure .....99% positive..... that I mocked it up with stock 14" rims. I don't remember if the pics went on NWDE or Ratsun. I'm sure I've still got them, but I'm also sure they're buried!!! 1 Link to comment
BEEBANI Posted November 13, 2010 Author Report Share Posted November 13, 2010 you're probably right Mike, I know that Brandon and I never had 14's on either of the rigs we put them on. 1 Link to comment
BEEBANI Posted December 14, 2010 Author Report Share Posted December 14, 2010 got an extra pair of these sitting here if any body is interested Link to comment
kaoss Posted December 30, 2010 Report Share Posted December 30, 2010 This may be a dumb question, but does this narrow the distance between wheel mounting surface to wheel mounting surface? Link to comment
BEEBANI Posted December 30, 2010 Author Report Share Posted December 30, 2010 yes, by 1/4" Link to comment
BEEBANI Posted December 30, 2010 Author Report Share Posted December 30, 2010 well, it spaces the wheel out 1/4"...the thickness of the rotor Link to comment
kaoss Posted December 30, 2010 Report Share Posted December 30, 2010 Damn, I need a 1/4 " in the other direction! Link to comment
BEEBANI Posted December 31, 2010 Author Report Share Posted December 31, 2010 actually, after recovering from my senior moment, I realized that the spacing would be the same since your removing the drum and installing a rotor in its place. Link to comment
kaoss Posted December 31, 2010 Report Share Posted December 31, 2010 And the rotor is no more narrower than the drum. :( Link to comment
BEEBANI Posted October 31, 2011 Author Report Share Posted October 31, 2011 bump got 4 sets of these in stock Link to comment
Radiant-Designer Posted October 31, 2011 Report Share Posted October 31, 2011 looking forward to doing this ASAP Link to comment
BEEBANI Posted May 15, 2012 Author Report Share Posted May 15, 2012 Bump.. Got a set ready to ship, and should have 4 more sets done this weekend. Link to comment
koyoteracing Posted July 3, 2012 Report Share Posted July 3, 2012 I need a set ASAP ! Can you send me your pay pal info please !! Link to comment
BEEBANI Posted July 3, 2012 Author Report Share Posted July 3, 2012 Beebani23@msn.com Link to comment
77ka24de620 Posted July 29, 2012 Report Share Posted July 29, 2012 u have front and rear brackets dont u??? how much shipped to 91761... Link to comment
