Josh K. Posted August 16, 2016 Author Report Share Posted August 16, 2016 I have a "orange needle" tach and gauge set. I also have a nicer white needle gauge set without the tach. I'm considering painting the needle on my tach white and going with the white set. It would match up to my vdo gauges. Thoughts? 1 Quote Link to comment
Draker Posted August 16, 2016 Report Share Posted August 16, 2016 I don't see why not? 1 Quote Link to comment
Josh K. Posted August 16, 2016 Author Report Share Posted August 16, 2016 Me neither. Not sure which one is more rare. Not that I really care... I'm sorting all the wiring right now. Killed the MAP and the break out box for my ECU. I know how I killed the MAP but the break out box I have no clue... Should have everything ready this weekend to try again. Lots of little thing to address with the wiring and motor. One step at a time.. 1 Quote Link to comment
jeph Posted August 16, 2016 Report Share Posted August 16, 2016 I have a "orange needle" tach and gauge set. I also have a nicer white needle gauge set without the tach. I'm considering painting the needle on my tach white and going with the white set. It would match up to my vdo gauges. Thoughts? i have a oem 510 tach with white needle that is missing a few parts and needs cleaned ill sell you for cheap ill take pics tomarrow, that way you can have one of both instead of messing with the orange needle one 1 Quote Link to comment
Josh K. Posted August 16, 2016 Author Report Share Posted August 16, 2016 Sounds good! You get over the plague? 1 Quote Link to comment
jeph Posted August 16, 2016 Report Share Posted August 16, 2016 Sounds good! You get over the plague? yup still got a permanent headache but doc said it should go away in a couple days glad the cold sweats and stuff are gone it sucked lol, 1 Quote Link to comment
Josh K. Posted August 16, 2016 Author Report Share Posted August 16, 2016 I hate being sick. I turn into a little bitch :) 1 Quote Link to comment
shacks510 Posted August 16, 2016 Report Share Posted August 16, 2016 The white needle gauges were a one year deal. They don't have the white ring on the face between the numbers and needle, whereas the orange needle gauges do. 1 Quote Link to comment
Josh K. Posted August 16, 2016 Author Report Share Posted August 16, 2016 Good info. Thanks man. Wish I would've kept the white needle gauge set I had back in the day when you could drive a perfect 510 out of a junk yard for $250... 2 Quote Link to comment
DISLEXICDIME Posted August 18, 2016 Report Share Posted August 18, 2016 I always liked having the factory clock 1 Quote Link to comment
Josh K. Posted August 30, 2016 Author Report Share Posted August 30, 2016 I'm dying over here. Been fighting the EFI to get the idle to lean out. She doesn't like to idle at 14.7. I've got that mostly worked out, lot's of small stuff fighting me still. Now I need to remove the stub axles from the diff and they won't come out! Their held in by circlips and should pop right out. Tried prying and even used a slide hammer. Nothing! I'm about to buy an R180 LSD and new axles/cv's. Kinda pissed off right now. ..... I won't give up just not sure my next path. 1 Quote Link to comment
thisismatt Posted August 30, 2016 Report Share Posted August 30, 2016 Pic of axles/diff? 1 Quote Link to comment
q-tip Posted August 30, 2016 Report Share Posted August 30, 2016 Pic of axles/diff? Yes. 1 Quote Link to comment
Josh K. Posted August 30, 2016 Author Report Share Posted August 30, 2016 Stock Subaru CVs with the shit cutoff and flanges welded on. Subaru R160 VLSD. The axles went in easy and you can move them in and out slighty and feel the circlip. I need them to be removable if I route the exhaust over the driver side. I'll probably bail on that and route it underneath like everyone else so I can just move on. I don't have time for bullshit at this point. Too much to do. 2 Quote Link to comment
Josh K. Posted August 30, 2016 Author Report Share Posted August 30, 2016 Maybe I need a larger slide hammer. I can only imagine the bearing races would get dented and wear out fast. 1 Quote Link to comment
Lockleaf Posted August 30, 2016 Report Share Posted August 30, 2016 Make a cv shaft remover. Buy a couple of pickle forks and widen them (with whatever steel you have) enough to get around the shaft tip. If you have 2 you can stack them if one isn't tall enough. Here's the real ones 1 Quote Link to comment
thisismatt Posted August 30, 2016 Report Share Posted August 30, 2016 Pry them between the flange and the bearing cover, careful not to damage the seal cover 1 Quote Link to comment
Josh K. Posted August 30, 2016 Author Report Share Posted August 30, 2016 I have a plate bolted to the face and a slide hammer bolted in the center. I'll get a bigger slide hammer tomorrow and try again. Prying didn't work. 1 Quote Link to comment
q-tip Posted August 30, 2016 Report Share Posted August 30, 2016 I 90'd a pry bar trying to pop a CV axle out of my old Tacoma (front cv's were is favorite thing the eat) it takes a really hard shock to pop them out. I ended up with a bigger bar had a friend mule kick it while I held it in place. 2 Quote Link to comment
Josh K. Posted August 31, 2016 Author Report Share Posted August 31, 2016 I rented a big ass slide hammer and the driver side popped right out. Passenger is stuck. I could care less about the passenger side as I just needed to remove the driver side. Carry on... I did pick up a brand spanking new Chevy Malibu tonight. It's super comfy and has all kinds of cool tech. I dig the Android Auto. Wheels are kinda "meh" but the 16% rebate made up for it.. 4 Quote Link to comment
Josh K. Posted September 5, 2016 Author Report Share Posted September 5, 2016 Just wait. I got plans for that car ;) Here's my inspiration.... Windows are tinted. Rims are next. Waiting on springs to be on the market.. Nothing easy about 3" exhaust on a 510. It's an engineering feat to keep it tucked. Gonna have to make a short hard line over the "hump" section and I'll wrap the pipe with header wrap to keep the heat down. Gotta hang the rear sheet metal and weld it all together before I can hang the muffler. There's no wiggle room with v-band clamps and tight clearances. It sounds beast though ;) 5 Quote Link to comment
Josh K. Posted September 5, 2016 Author Report Share Posted September 5, 2016 New Hardline done. Just need a new soft line made. 3 Quote Link to comment
Josh K. Posted September 20, 2016 Author Report Share Posted September 20, 2016 Been busy living a jet setter lifestyle... Gonna be back to work on the car in the next few weeks. Hopefully I'll get motivated again. I'm really thinking about switching to a Wilwood 1" Master Cylinder. I have a B210 Booster so it should be fine. Main reason is I can buy it with the remote mount kit to save me time. https://www.summitracing.com/parts/WIL-260-7563/?rtype=10 Thoughts? Ordered a set of these in 20" for my Malibu. Should be here next week... Same wheels as the Impala above but 20" instead of 22" and black with machined faces... 2 Quote Link to comment
q-tip Posted September 22, 2016 Report Share Posted September 22, 2016 Those should look pretty good, not bad looking for a modern concave style wheel. Quote Link to comment
