Josh K. Posted August 2, 2017 Author Report Share Posted August 2, 2017 I love when you think you ordered one piece and ten show up... If anyone needs 5/8" to 5/16" reducers for their fuel vent just lmk... Quote Link to comment
q-tip Posted August 2, 2017 Report Share Posted August 2, 2017 1, 10 close enough right? Quote Link to comment
Josh K. Posted August 5, 2017 Author Report Share Posted August 5, 2017 I guess so.. better than nothing?.. Funny story... If the launch control setup has a value greater than zero in the "Launch Max Speed" and you don't have a speed signal to the ECU it will think you're sitting still and the result is a Rev limiter of 4500RPM..... That's explains why it was breaking up at that RPM... This system is new to me so I missed that setting... Quote Link to comment
Josh K. Posted August 5, 2017 Author Report Share Posted August 5, 2017 Not only did disabling the launch control fix the breaking up at 4500rpm it fixed the idle issue and drivability issues. Now I need to know why so I can fix for good. She pulls hard as a freight train at 12psi and purrs like a kitten at 800rpm. Crazy. She has as much power as your right foot desires... And that's at 13deg of timing.. it still has a few degrees left.. timing makes power.. until detonation occurs.. 2 Quote Link to comment
Josh K. Posted August 5, 2017 Author Report Share Posted August 5, 2017 Had to fix an oil leak at the filter relocator, replace the radiator caps with non "shitty AutoZone" guaranteed to leak ones.. next I need to reflare one brake line at the master, bleed the brakes again and then it's time to get back to body prep so I can throw down some primer/sealer and put the windows in. I would like to drive it for real and not just illegal runs down back roads 2 Quote Link to comment
Josh K. Posted August 5, 2017 Author Report Share Posted August 5, 2017 Cleaning the garage so the 510 is outside. Everytime I look at it she says "take a picture of me"... 5 Quote Link to comment
Josh K. Posted August 13, 2017 Author Report Share Posted August 13, 2017 There is work being done.. Stripping to bare metal for primer.. 6 Quote Link to comment
Josh K. Posted August 14, 2017 Author Report Share Posted August 14, 2017 I decided I really don't want to pull the windshield and back window to paint this winter. So.. I'm gonna do all the body work and paint the body now. Might as well do it once. That means I had to finish the wiring and install connectors so I can remove the dash. It's almost done. Just need to install the cut off switch and clean up some loose ends. 6 Quote Link to comment
datsunfreak Posted August 14, 2017 Report Share Posted August 14, 2017 Is that purple on the trunk the final color? Quote Link to comment
Josh K. Posted August 14, 2017 Author Report Share Posted August 14, 2017 Is that purple on the trunk the final color? That trunk lid is from a car I owned when I was 21. The inside of the trunk was a different purple than the exterior fortunately. 2 Quote Link to comment
datsunfreak Posted August 14, 2017 Report Share Posted August 14, 2017 Ha! The paint was so shiny I thought you did it recently... :P Quote Link to comment
Josh K. Posted August 16, 2017 Author Report Share Posted August 16, 2017 Just gotta remove the gas tank, mask off the frontend and then it's time to focus on the body. 6 Quote Link to comment
jrock4224 Posted August 29, 2017 Report Share Posted August 29, 2017 I love when you think you ordered one piece and ten show up... If anyone needs 5/8" to 5/16" reducers for their fuel vent just lmk... almost as great as the time i ordered 1 a14 thermostat but didnt read it was a case of 24 ... luckily it got lost in shipping and rock auto credited me before i realized i had 78 dollars in thermo stats 3 Quote Link to comment
Josh K. Posted December 7, 2017 Author Report Share Posted December 7, 2017 I wonder what happened to this project? It's still moving along, I just don't post much about it anymore. I've been working on the metal getting it ready. Had to fix some panel warpage from welding on the flares. Shrinking disc to the rescue!! Much better.... Hung the door and started on the panel alignment/gaps. The back of the fender was a little high and the lower corner was rusted so I killed two birds with one stone and cut off the lower corner. New corner and properly aligned panel. The door gap looked horrible. SO I welded the leading edge of the door and reground the gap Next is to shrink the door panel to get the crown out of the panel. All 510 doors kinda bulge outward and I want the panels to be flat and straight. Kinda scary so hopefully I don;t mess it up.... This car will be painted and on the road this spring barring any unforseen life obstacles. I'm pretty confident it will and I'll be at canby for the first time... Cross your fingers... 10 Quote Link to comment
edekalil Posted December 24, 2017 Report Share Posted December 24, 2017 This is one badass build! 1 Quote Link to comment
Josh K. Posted February 10, 2018 Author Report Share Posted February 10, 2018 Sun came out today, kinda got me excited to work on the car. Will I or won't I? I guess we'll see... Quote Link to comment
Josh K. Posted February 10, 2018 Author Report Share Posted February 10, 2018 Here's some old pics: Shrank the shit of the door skin. The stock door skins bulge out about a 0.25". It was sketchy but I made it better... 5 Quote Link to comment
r0p0doe Posted February 18, 2018 Report Share Posted February 18, 2018 Best flares I've ever seen on a 510, and I personally prefer stock but damn those things make me drool :thumbup: 1 Quote Link to comment
Josh K. Posted March 15, 2018 Author Report Share Posted March 15, 2018 Thank you sir. Finally got the new Golf MK2 front fenders. I did a shit job when I made the front fenders last time so I'm redoing them... New fenders to cut up... Stripped the front fender to bare and started mocking of the flare: 3 Quote Link to comment
Josh K. Posted March 16, 2018 Author Report Share Posted March 16, 2018 I'm almost 100% gonna change the color. This car deserves more then a basic color like Anvil... This is what I'm probably going to do.. 3 Quote Link to comment
Josh K. Posted March 16, 2018 Author Report Share Posted March 16, 2018 And yes Datsunfreak, you've seen that color somewhere.. 2 Quote Link to comment
Lockleaf Posted March 16, 2018 Report Share Posted March 16, 2018 Metallic grape soda. I dig it. Also, hooray metal flared car! 2 Quote Link to comment
datsunfreak Posted March 16, 2018 Report Share Posted March 16, 2018 And yes Datsunfreak, you've seen that color somewhere.. :rofl: What made you go whole donor fender instead of just the flare? Quote Link to comment
Josh K. Posted March 16, 2018 Author Report Share Posted March 16, 2018 :rofl: What made you go whole donor fender instead of just the flare? The patch panels are the rear flares. I use the front flares. Quote Link to comment
datsunfreak Posted March 16, 2018 Report Share Posted March 16, 2018 The patch panels are the rear flares. I use the front flares. i thought I had seen front patches too... Maybe not... ^_^ Quote Link to comment
