where to get r16 pistons
67wrx
  • Replies 12
  • 3 weeks later...
R16 Carburator
Partnumber: 1129
1600 SU High Flow Re-usable Air Cleaner Assembly Can be purchased with or without velocity stacks. Price is for air cleaner, drilled back plate and gaskets only. Now 1600 owners can increase their breathing.Note: There is no provision in the back plate for PCV hose mounting. There are after market pcv filters that can be attached to your valve cover breather outlet. Venting directly into the air filter can damage the assembly.
$199.00
R16 Carburator
Partnumber: 1129
$199.00
R16 Carburator
Partnumber: 1129
1600 SU High Flow Re-usable Air Cleaner Assembly Can be purchased with or without velocity stacks. Price is for air cleaner, drilled back plate and gaskets only. Now 160 owners can increase their breathing.Note: There is no provision in the back plate for PCV hose mounting. There are after market pcv filters that can be attached to your valve cover breather outlet. Venting directly into the air filter can damage the assembly.
PCV hose should not be attached to the back plate! This is a sure fire screw up the SU pistons. The factory filter housings bring the PCV hose in BEFORE the filter so that the filter can [obviously] filter out gross oil droplets and crud and not feed them to the SU intakes. The finned cast aluminum valve cover and riveted in drip plate capture almost all of the oil fumes and recondense them and return them to the oil sump without need for an individual PCV valve. A legal PCV recirculation without the pesky valve!
There were not any parts for sale on this thread. The above were talking about where to get some parts and the part numbers they found. You had even told him where to get the parts and he couldnt find it at the dealer as mentioned so he let us know where he found them with the part number.
