Supercharged VG30 ,stretched 720 Pickup
  • Replies 584
  • 4 months later...
Very original build. Your fab work is amazing. I look at tons of the stuff you have done and realize just how sad my custom Z bumper mounts and my throttle cable adapter are. :) Awesome stuff.
@ Collisions and Customs: He is sitting on 5 lug rims, so he has some kind of front suspension swap in there already. He says he likes to keep it Nissan so it's likely S13 or Z32 suspension bits.
  • 1 month later...
  • 2 months later...
  • 6 months later...
Hi
I am back , been super busy doing everything else, so this past weekend I dug out my 720 from the corner, so its time to go at it again this winter, there is so much to do !!!!! OMG .
I have to build a driveshaft,fuel tank , finish welding the inside of the cab, and rear frame, build exaust, interior, run brake lines and wire it all, then take it all apart and paint it, shit I am tired already just thinking about it !!!!
  • 1 month later...
  • 3 weeks later...
Hi
I had some time to work on Blue Thunder ( my truck was named Blue Thunder because it was blue and sounded like thunder) this weekend for a bit, I was having a hard time with suspension, finding shocks that would work with my modified Z32 diff, so I built cantilevered setup, with some used JIC Shock's
I ran out of time ,but got enough done to test it !!!!!!
Now I can adjust ride hieght and spring preload and rebound all separate !!!!!!!
Lots of pic's ........................I know i like to see project stuff too
