Supercharged VG30 ,stretched 720 Pickup
  • Replies 584
Update
Slowly going back together , unbelievable amount of stuff to do , everything takes longer than ya think ......
Was hoping to get the box back on tonight , but its snowing here and to get the box on the truck , it has to go half out side . so not going to happen tonight.
  • Like 9
Update
Hi life has been getting in the way , dug out my glass bead cabinet from my shed , it needed a new window and fresh media , so I got some pieces blasted and repainted .
Also made up some steel Brake lines m and got the parking brake bled .
  • Like 7
Update
Here is a little trick I came up with a few years ago , it's to clean up small parts like little brackets or bolts , you take a small plastic jar , this one is a peanut butter container , drill a hole to fit the nozzle of the gun and a few holes to let the media out , it seems to work very well .
the next thing is an old shop vac , drill a hole in the lid , put the hose in the lid and a filter on the exhaust side , this helps reduce the dust in the box to see better and helps keep the dust down in the shop , when the weather is better I set it up outside.
Getting ready to put the box back on !!!!!
got the parking brake all working , will install the cable now that I can see how it has to go to clear everything
  • Like 9
Love the tip for blasting the small parts.  I've been using this for many, many years....works great.  But......I think if the open end with the screen was done on a jar with a lid like yours, it would be perfect!!!  I'm def going to be getting couple of jars with screw on lids. :)  ....and this is a "before" shot....only one I had that showed the cup nicely.
  • Like 5
  • 3 weeks later...
Update
Hi sorry was out of town , so no work on Blue Thunder .
Started to build the exhaust tip .............going to be awesome !!!!!! I know you guys are going to love it .
Hope to have it done this weekend , ( the exhaust tip that is )
  • Like 4
update
A little more of the Exhaust tip ...................
Building a mold for a carbon cover with two different size slash cuts ......
This is just roughed in , still needs to be filled and finished sanding also a closing plate for the two big holes .
so that's all for today .......
  • Like 5
Update
Hi been super busy with everything else lately .
Made a cutter to countersink the fasteners for the carbon exhaust tip cover .
I used a piece of tool steel ( parting tool from the lathe ) and a 1/4 inch drill bit , zip cut a slot in it and tacked the blade in.
Also got a new ( new to me ) tool Small milling machine , same brand as the lathe , it's old and needs some TLC , but it works ok for now , need some new cutting bits . should come in handy !!!!
Hope to get some time in on the truck this weekend .................
  • Like 7
  • 3 weeks later...
Hi. Any updates on this? Really enjoying following the build
Hi Been super busy , life & work getting in the way , I have done some stuff , trying to get the shop a little better organized also , going crazy !!!
buried in stuff and can't find things and need room to work .................stay tuned and thanks for following
Cheers Fast720
Hi Everyone
Sorry but I have been stupid busy doing everything but working on my truck and my dead line is June 24th .
Went to work on Blue thunder one night a couple of weeks ago , and got totally pissed off when I couldn't find a couple of things .
was going to glass bead my front Calipers , couldn't find the one that was off the truck , next was a piece of tube for the exhaust tip , so I had enough and did a sort and reorganize .
I had 4 buckets of metal that were driving me crazy !!!!!
So I built a rack .
I will be back on the truck this weekend !!!!
Sorted all the short stuff into plastic bins , now easy to see what's there !!!
All on wheels so easy to move and clean or ( look for that C clip that flew across the shop ) LOL
So thanks for the nudge and fallowing ...........please stay tuned
More to come
  • Like 10
Update
Worked on Blue Thunder today !!!!!
Got the exhaust tip fabricated and welded , still have to prep the mold for the carbon surround , hopefully tomorrow ,if not I will be working under the hood , on inner fenders and engine accessories .
inside before welding
This was fun to make ............
  • Like 7
