Fast720 Posted October 22, 2016 Author Report Share Posted October 22, 2016 Update solved the hood problem !!!! It's a little Mad Max ish , still not sure if I like it ....... I will build another open hood for the summer time I wont know if the open hood I have will still work until I get the fenders and hood all lined up properly , I still have the front cross member to build , I need all the body parts in there proper place before I can make it with the forward cab mounts. So here is a bump on a scoop ............. Bead rolled a new piece of 22 gauge satin sheet metal 3 Quote Link to comment
DatMo Posted October 22, 2016 Report Share Posted October 22, 2016 That's still awesome imo but the blower sticking out is more aggressive 2 Quote Link to comment
Fast720 Posted October 22, 2016 Author Report Share Posted October 22, 2016 That's still awesome imo but the blower sticking out is more aggressive Hey DatMo yes I agree with you I like it sticking out of the hood also ,and with the paint scheme it will be awesome. But this truck is going to be used all year round , and here in the winter it rains frigin sideways !!!!!!! , so I will have two hoods one open for spring to fall and this one with two scoops . 3 Quote Link to comment
datsunfreak Posted October 22, 2016 Report Share Posted October 22, 2016 so I will have two hoods one open for spring to fall and this one with two scoops . Forget what I said. This is the best plan. ^_^ 3 Quote Link to comment
Rhino13 Posted October 22, 2016 Report Share Posted October 22, 2016 I think it looks badass! It fits the aggressiveness of the rest that you've done to it body wise. 1 Quote Link to comment
DatMo Posted October 23, 2016 Report Share Posted October 23, 2016 Awesome call and you get the best of both worlds. Really envy your work. 1 Quote Link to comment
Fast720 Posted October 24, 2016 Author Report Share Posted October 24, 2016 Update PhotoBucket is really starting to piss me off !!!!! Worked on the front end today , found the damaged inner fender and some rust , This laser is really awesome it is self leveling , has a vertical and horizontal lines 3 Quote Link to comment
mklotz70 Posted October 24, 2016 Report Share Posted October 24, 2016 make/model on the laser? Looks like it says Laser Genius 650? Not finding one that looks like yours. 1 Quote Link to comment
Fast720 Posted October 24, 2016 Author Report Share Posted October 24, 2016 make/model on the laser? Looks like it says Laser Genius 650? Not finding one that looks like yours. Hi it's a Infiniter Level Laser Genius 6150 , I have had it for several years , very handy 3 Quote Link to comment
Fast720 Posted October 25, 2016 Author Report Share Posted October 25, 2016 Update Worked on getting the front end straightened up today , had to cut the inner fenders , they were tweaked and wouldn't let the nose stay in the right place , weled the rad support back in and got it as square as I could , still need to drill some new holes in the fenders to hold it .but I can move onto the cab mounts in the front and the bumper receiver , then onto the body drop on the box and the four link !!!!! Looking forward to that . This is way better than it was , there is still room for adjusting , I need to re drill some of the fender holes on the passenger side 7 Quote Link to comment
Fast720 Posted October 26, 2016 Author Report Share Posted October 26, 2016 Update Got the front cab mounts done , just have the bumper bracket receivers to make and then is on to the box , and the four link !!!!! 5 Quote Link to comment
DatMo Posted October 26, 2016 Report Share Posted October 26, 2016 MAN YOURE SO CLOSE 1 Quote Link to comment
Fast720 Posted October 28, 2016 Author Report Share Posted October 28, 2016 Sorry tried to update but Photo Bucket is down , is there some other way , PB is really pissing me off , I don't have 45 minutes to an hour everyday to upload pics !!!!! 1 Quote Link to comment
Fast720 Posted October 28, 2016 Author Report Share Posted October 28, 2016 Update Bumper mounts Captive nuts ( welded from the other side ) On to the box chop & drop ( this was not fun ) Got the box standing plum and used the laser level to mark my lines to cut , works very well for this type of thing Welded a bar across the top to hold it square Well I hope I did this right !!!! it looks like it should work out , I have to make some panels for the bed to weld up to . 5 Quote Link to comment
wayno Posted October 28, 2016 Report Share Posted October 28, 2016 How did you cut it? 1 Quote Link to comment
Fast720 Posted October 29, 2016 Author Report Share Posted October 29, 2016 Hey Wayno I cut the lower ribs first with a Sawzall and then cut the rest with a Zip cut disc , I left some tabs until the end so it would hold it up and not bind , it took longer to lay out than to cut , hop to get back on it today 2 Quote Link to comment
Fast720 Posted November 1, 2016 Author Report Share Posted November 1, 2016 Update Still working on the box , been slow , other things getting in the way . Hope to have the floor tacked back in tonight or tomorrow .......but there is a lot of prep , like removing the frigin undercoating and paint in the weld areas. 3 Quote Link to comment
dukerollo Posted November 1, 2016 Report Share Posted November 1, 2016 Good work, and not for the faint hearted, that is a lot of real estate to weld without it twisting like a pretzel. You know how to get shit done. Quote Link to comment
Fast720 Posted November 2, 2016 Author Report Share Posted November 2, 2016 Good work, and not for the faint hearted, that is a lot of real estate to weld without it twisting like a pretzel. You know how to get shit done. Thanks..................I know its a huge undertaking to body drop anything , I sure didn't want to , I didn't want to shorten the box in the first place either . Quote Link to comment
Fast720 Posted November 2, 2016 Author Report Share Posted November 2, 2016 Update Still working on the box ........Surprise !!!!!!.............sh*t load of work 7 Quote Link to comment
wayno Posted November 2, 2016 Report Share Posted November 2, 2016 WOW :rofl: :rofl: :rofl: :thumbup: 3 Quote Link to comment
Fast720 Posted November 3, 2016 Author Report Share Posted November 3, 2016 Update Getting the box buttoned up slowly , still have to make the little piece that goes at the back of the bed . Got it all tacked up and straight ,the side rails were bowed out in the middle about 3/16ths of an inch after welding the side panels in. Had to strap it all in the right place and pull it evenly , was fun getting it to all line up before taking. Here you can see how straight it came out Here is how it looks from the bottom It turned out not too bad , still some welding to do and the little part at the back by the tailgate. 8 Quote Link to comment
Charlie69 Posted November 3, 2016 Report Share Posted November 3, 2016 Nice work! Beautiful! 1 Quote Link to comment
dukerollo Posted November 3, 2016 Report Share Posted November 3, 2016 Are you hammer forming the recesses in the panels, or is it strictly bead roller work? Either way, super nice job. 3 Quote Link to comment
mklotz70 Posted November 3, 2016 Report Share Posted November 3, 2016 Always impressed with your work! 3 Quote Link to comment
