brake booster issue
i have a 76 datsun 620 that had sat for about 20 years, when off i get a decent brake pedal, but if the truck is running the brake will go strait too the floor, i am thinking the check valve for the booster is bad because it vents through the vacum line when it is off and i push the pedal,
but how do i test the booster too? any ideas or sugestions, i am just trying to avoid buying parts i dont need
  • Replies 24
Sounds fine to me. The booster simply takes your foot pressure and magnifies it to increase the brake pressure. It uses engine vacuum to do this.
With engine off the peddle feels stiff or firm because you have no help from the booster. With engine on, the booster will increase your input several times over and of course the peddle will drop down some. If you system is working properly, pump the peddle several times with engine off. Push down on peddle firmly and turn engine on.... peddle should drop slightly. Everything is fine. Peddle dropping to the floor is not.
The one way valve allows the engine to draw air from the booster into the intake. The booster stores this vacuum and when the motor is shut off, the one way valve prevents air from getting back in. If your engine is off and you pump the brakes you will hear the vacuum being used to assist the brakes. 2-3 pumps and it is all used up.
You have 4 wheel drum brakes so you should adjust the shoes out closer to the drums. Right now most of the peddle travel is wasted moving all the shoes out toward the drums.
Bleed the brakes. There may be air trapped in the lines and 20 year old brake fluid is a no no.
Even with a booster you're still physically connected through to the MC when you push on the pedal, so unless something is broken inside the booster (not likely) then I'd still lean towards your having a MC, air in the lines, or other brake system problem.
Bleed the brakes and flush out all the bad fluid and air. After you have done that, you can see how it acts. My guess is that it has bad fluid/air in the lines. And after sitting for that long it should be replaced.
i have brand new master, all new wheel cylenders, brakes work when the truck hasnt been running, but when i start it the brake pedal goes to the floor with zero pedal feel, and no brakes.
i have bled the brakes multiple times, and with the engine running the brakes wont work
Your pedal should never go to the floor is the bottom line. Air in the lines, brakes out of adjustment, leaks, bad MC seals, failing-but-not-leaking soft lines (ballooning)...any of these could allow the pedal to go to the floor. With the engine off, how much pressure are you applying to see if the pedal drops excessively far? What if you really stand on it?
hmmmmmmmm All of the Above Advice ^^^ Seems to be Solid.
If you really feel that the check valve is bad ( it has turned 2way instead of 1way ) , my suggestion would be to simply straight line it to the intake , and see if there is a difference between ----> having your current check valve and a straight vacuum hose. ---> If you don't see a difference you will have a problem with either the check valve or booster <--- ( At that case I would try or buy another check valve , have one from a spare truck or friend to borrow )
after doing some testing on it today, all your ideas are good.
i am thinking the old flexable brake lines need replaced, and/or maybe it got some air in the system again, but i am leaning towards the flexable lines, and they probably should be changed either way, so i will get them and bleed it all again, i bet that fixes it.
the check valve works and the booster is holding a vacum, unless theres another part in the booster i dont understand.
i will have to order the brake hoses so it may be a while before i have an update.
Thanks for all the input
If the one way valve were reversed no vacuum can get to the booster and there would be no power assist. Think about it.
The booster either works or it does not. Without power assist the brakes will work but the effort is high. With the booster working the brakes will work and are much easier to apply. You say that the brakes work with motor off and don't work when it is on.... this is impossible.
How can you say the brakes don't work with the engine running? Did you drive it? Or are you assuming because the pedal drops it isn't working? I already said the pedal would be stiff without booster assist and the pedal softer with it.
The biggest cause of excess pedal travel is trapped air OR the drums not adjusted.
Did you adjust the drums yet or are you assuming they are ok? If bleeding, don't forget the NLSV (load sensing valve) under the pass seat.
yep i know i need to bleed the load sensing valve, everything checks out good on the booster, so i moved on to checking over the adjustment of drums and i am replaceing the flex lines and then bleeding the whole system just like the haynes manual says, but sadly i am working next few days so it will be a bit before i get it finished
how often do you guys think a brake booster goes bad? i mean only if the diaphram busts right? i just bought a reman one and havent had a chance to try it out, when installing my new engine i removed my old booster and when i turned it over a bunch of black brake fluid poured out of the vacumm hose i figured ah while im at it and just went a bought another one, my brakes did not work super good with the old booster even after i replaced the shoes, rebuilt the cylinders, and flushed and bled everything. i hope this new booster helps, i have done alot to make the truck go faster but not much in the stopping department. :lol:
more often then ya think ! :lol:
  • 2 years later...
Sure, a vacuum leak could cause that. Easy to diagnose. Step on brake pedal, idle goes up, vacuum leak. If really bad, leaking all the time, pinch the vacuum hose with pliers and the idle will change. Confrmed that a few times.
