brittney Posted July 16, 2010 Report Share Posted July 16, 2010 I'm still looking for a grill and front brake lines if anyone knows where i can get them. i rarely check the site because i only have internet on my phone and this page doesnt load if you could email me any information that would be amazing, id like to get my wagon on the road this next week! -brittney email, brittneyj35@yahoo.com Quote Link to comment
brittney Posted July 18, 2010 Author Report Share Posted July 18, 2010 Also a waterpump. Can't seem to find one. Quote Link to comment
Paul G. Posted July 19, 2010 Report Share Posted July 19, 2010 I'd hit up your local hydraulic shop. They can make brake flex hoses to order based on an old hose you hand them. Quote Link to comment
raceneely Posted July 19, 2010 Report Share Posted July 19, 2010 Brittney For 411 brake lines if you still have SAE lines and not metric conversion go to Anplumbing.com if it is a male / female hose order part number 63040512 ( the last 2 digits are lenght in inches. If it is lonnger just change last 2 digits) if it is a female / female line you can build that yourself with 640503 ( ends qty 2 ) 6000031 ( hose qty by the foot ) Assembly video is on the site under "coated #3 assembly video" in the tech videos section if they are metric change number to: male / female 63081012 ( longer if needed ) female / female build them with 640603 ( qty 2 ) same hose ( by the foot ) Neely Quote Link to comment
AZhitman Posted July 19, 2010 Report Share Posted July 19, 2010 Making this WAY too hard. Go to NAPA and get brake hoses for a Datsun 520 pickup. Here's the ones I bought: http://www.napaonline.com/Search/Detail.aspx?A=UBP36737_0073594116&An=599001+101967+50018+2018052 Brake Hose - Front Product Line: NAPA ULTRA PREMIUM BRAKE PARTS Part Number: UP 36737 Quote Link to comment
AZhitman Posted July 19, 2010 Report Share Posted July 19, 2010 Also a waterpump. Can't seem to find one. http://www.datsunparts.com/1506 Quote Link to comment
MikeRL411 Posted July 19, 2010 Report Share Posted July 19, 2010 http://www.datsunparts.com/1506 I looked at the picture of the Water pump listed for the RL411 and the description of the 1 inch pump shaft protrusion and the picture of the wider spinner leads me to hope that the RL411 upper pulley would just bolt on and align with the alternator and crankshaft pulley like my roadster water pump plus spinner transplant does. If someone does order this water pump, please give feedback on this drivebelt alignment. By the way, that datsunparts site is a real gem. Quote Link to comment
brittney Posted July 20, 2010 Author Report Share Posted July 20, 2010 thank you guys!! this really helps, all she needed before she runs! if i could figure out how to post pictures i would, just recovered and painted the dash, painted trim, new carpet, new upholstered seats, soon to have *today* wood grain headliner! **just ordered the water pump off datsun parts, thanks azhitman! mikerl411, the guy said it is a different pulley, he has the pulleys and hell put the right one on for you before its sent! Quote Link to comment
MikeRL411 Posted July 20, 2010 Report Share Posted July 20, 2010 **just ordered the water pump off datsun parts, thanks azhitman! mikerl411, the guy said it is a different pulley, he has the pulleys and hell put the right one on for you before its sent! Sounds good! I personally would keep the old water pump in case of a future need or if the replacement pulley supplied is not quite right. The RL411 original is machined in a "bell shaped" cross section to fit the much larger hole in the RL411 fan and provide correct drive belt alignment. Now your only items needing a check are the engine and transmission mounts. The one inch protrusion of the pump shaft looks scary, but that's looking down from the top. The clearance to the radiator core is tight, but unless you have weak motor or transmision mounts a sudden stop won't let enough forward motion to build up and hit the core. Quote Link to comment
brittney Posted July 23, 2010 Author Report Share Posted July 23, 2010 got thoes brake lines from napa, wrong ones didnt fit? Quote Link to comment
Paul G. Posted August 1, 2010 Report Share Posted August 1, 2010 I agree that NAPA UP36737 is way to short to replace the front flex hoses on the drum brake cars (PL models.) That hose looks like it will be a good replacement for the rear flex hose on 410's and 411's though. It is about 1.5 inches longer than the stock hose on my '66 WPL411. That will allow it to hang about 5/8th inch lower than the original one which is still well above other surrounding undercarriage parts. With any luck it will also relax the bend at the rear axle where all the outer rubber has flaked away on my original brake hose (and you really shouldn't drive with the cloth inner jacket showing.) Quote Link to comment
MikeRL411 Posted August 2, 2010 Report Share Posted August 2, 2010 By the way, the standard stress relief for the front disc brake hoses is a coil spring hooked to the brake backing plate and looped over the hose itself. It works, but gives me the chills. Steel on rubber is not a good idea. I found some cable tie wraps with attached loop for a screw to tie the cable to structure. Wrap the tail piece around the hose and clip off the excess, then put the spring loop through the eyelet. Much safer! Can't find the cable tie with the loop? Use the yellow plastic tie wrap from a garbage bag. Inelegant, but the spring fits through the slit in the body of the tie wrap. Quote Link to comment
