Z22 Torque Specifications
Rod
I am searching all over the net for the torque specs of the Z22 engine, but the only information i found is the Head torque, anyone have the specs for all the engine(rods,main bearings,intake,exhaust). I appreciate it.
  • Replies 9
Z20, Z22 and Z24 NAPS-Z Engines (1981 on)
General
Oil pressure: idle 10.7 psi
3000rpm 47 – 67 psi
Cylinder head warpage limit - .1mm
Compression pressure – std 171 psi
Minimum 128 psi
Valves and seats
Stem deflection limit - .2mm
Stem diameter intake – 6.965 to 6.980mm
Exhaust – 7.945 to 7.960mm
Inside guide diameter – 8.00 to 8.018mm
Stem to guide clearance intake - .020 to .053mm
Exhaust - .040 to .073mm
Limit - .1mm
Stem grinding limit .50mm
Spring free length inner – 44.1mm
Outer – 49.77mm
Installed height inner – 35.0mm
Outer – 40.0mm
Seat angle – 45 degrees 30 minutes
Seat width intake – 1.8 to 2.4mm
Exhaust – 1.5 to 1.9mm
Camshaft
Journal diameter – 32.935 to 32.955mm
End play - .2mm
Lobe height – 38.477 to 38.527mm
Lobe wear limit - .25mm
Runout - .2mm
Bearing inside diameter – 33 to 33.025mm
Oil clearance - .045 to .09mm
Engine Block
Deck distortion limit - .10mm
Cylinder bore:
Z22 – 87 to 87.050mm
Z20 – 1984: 85 to 85.050mm
Z20 – 1985: std, 85 to 85.010mm
Z24 – 89 to 89.010mm
Bore taper – less than .015mm
Piston/bore clearance - .025 to .045mm
Pistons and rings
Z22 std – 86.985 to 87.035mm
Z20, 1984 – 84.965 to 85.015mm
1985 – 84.965 to 84.975mm
Z24, 1984 and 1988, std 88.965 to 89.015mm
Z24, 1985 through 1987, std 88.965 to 88.975mm
Piston ring end gaps:
Top - .25 to .4mm
Second - .15 to .3mm
Oil ring - .3 to .9mm
Ring side clearance:
Top - .040 to .073mm
Second - .030 to .063mm
Crankshaft, connecting rods, main bearings
Con rod end play – std .2 to .3mm
Limit - .6mm
Crank end play – std .05 to .18mm
Limit - .3mm
Main bearing journal diameter – 54.942 to 54.955mm
Con rod journal diameter – 49.961 to 49.974mm
Journal taper std – less than .01mm
Limit - .03mm
Main bearing oil clearance std - .02 to .062mm
Limit - .12mm
Con rod oil clearance std - .025 to .055mm
Limit - .12mm
Flywheel runout limit - .15mm
Torque specs – ft lbs
main bearing cap bolts – 36
con rod cap nuts – 36
cylinder head bolts:
Z20 and Z24
Step 1 – 22
Step 2 – 58
Step 3 – loosen all bolts
Step 4 – 22
Step 5 – 58
Z22
1981 and 1982 – 51 to 58
1983 – 58 to 65
Exhaust manifold bolts/nuts – 12 to 15
Flywheel/driveplate/crankshaft bolts – 101 to 116
Rocker cover bolts - .7 to 2.2
Front cover to block bolts, 6mm – 3 to 7
8mm – 7 to 12
Intake manifold bolts/nuts – 12 to 15
Oil pan bolts – 3.5 to 5
Oil pump mounting bolts – 8 to 11
Valve rocker assembly mounting bolts – 11 to 18
Cam sprocket bolt – 87 to 116
Chain guide and tensioner bolts – 4.5 to 7
Crank pulley bolt – 87 to 116
This may be wrong, I'll check when I get home.
*Main bearing journal diameter – 54.942 to 54.955mm*
....not that it matters much. If new bearings are ordered the correct ones always come in the box.
Yeah that main bearing or crank main bearing journal size is incorrect. 54.9mm is for the 5 bolt L16/18 cranks. All 6 bolt that I have measured L20B, Z20/22/24 are 2.3599"-2.3600"
This is a mistake that even Nissan has not corrected in some of their FSMs. Haynes and Chiltons just copies the mistake.
They're wrong. Hell I have an '84 FSM for the 720 that shows the mains at 54.942- 54.955 OR 2.1631"- 2.1636"
I have measured 2-3 L20Bs, 2 Z20s, 2 Z22s and at least one Z24 and all were around 2.360" or about 60mm approx.
