Flipping / Reversing 510 crossmember
  • Replies 19
Jefe- Ty
Zerow- bring it down when your ready..will work for food :cool:
Jesse- that would've been sweet. Youll see how i kept it square in the pics.
Dennis- the owner will be modifying the stock 510 mounts.
Ok got busy today, took only 3 hours & bam !
as it looks stock, imagine looking down into the engine bay......
carefully marked lines. the upright ones must be straight up & down..
before i cut i welded a bar to keep it all square. I used a cut off wheel on my grinder...
& slid into it's new position...
welded in place...
at this point i cut off the brace. For looks & strength we decided to cap the ends of the mounts...
this lip must be removed so it doesnt interfere with the steering linkage...
prepped for primer / paint...
3 coats of gloss black.......
Ill include pics of the modd'd motor mounts soon. I may be making that part as well.
I will let you know when the L20B craps out. Knowing this motor, I'm sure its going to take a while...
  • 4 months later...
PCD: Did you lay out your vert. lines 90 deg. off the bottom of the crossmember? Just curious.
This was a low tech mod :D I simply welded the bar across the part before cutting, reversed & welded in place then cut off the bar. It lined up & bolted back up up w/no issues.
To mark the cut lines i set it on level ground then used my level to mark the lines.
I should be doing another crossmember soon, ill take more pix for sure.
  • 3 weeks later...
  • 6 years later...
