simple 280zx/510 strut questions
  • Please log in to reply
66 replies to this topic
#61 KlassicMotion
KlassicMotion
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,604 posts
  • Cars:'71 Dime, '66 Vtec Mini, '77 Honda 400F, '95 S14
Posted 27 May 2014 - 02:23 PM
My T3 camber plates came with three different sized bushings to use with the different inserts.
Here is another link for comparison:
http://community.rat...ar-shock-guide/
-Kyle"God gave man one brain an one penis, and only enough blood to use one at a time" ~Robin Williamshttp://community.rat...8-dges-install/ http://community.rat...r-510-is-risen/ http://community.rat...r-green-73-620/ http://community.rat...ar-shock-guide/ <p>
#62 That4doorKiD
That4doorKiD
  • Senior Member
  • PipPipPipPip
  • 407 posts
  • Cars:68 4-Dr 510, 72 Wagoon 510
Posted 11 January 2017 - 03:45 PM
I used my stock 510 struts,,, then shortened them ~2 inches..... and re-threaded the top of the strut tube
With a 4.5" coilover collar.... . I can put the front crossmember on the ground (I know you already commented on how low my car is,, and how you'd be worried about the tires hitting the flares)
If i shorten my zx struts, will using my 4.5 inch collars be short enough if I make the perch sitting flush with the top of the strut and top of the collar. HARD TO PUT IN WORDS
Basically... everyone has 7 inch collars/springs that they use for their coilovers. Thus perch is 7 inches below the gland nut or tip of the strut tube, which means more adjustability. Losing those 3 inches of adjustability with my 4 inch collar, will I still be able to slam my dime on 15s with the 4 inch collar? MR2 inserts and shortened struts.
Anyone know what I am trying to say please answer my question lol. THANKS
68 510     K i D
        :baby:
ee005e0e-ce50-425c-93b1-4d6f86b4909c_zps
#63 That4doorKiD
That4doorKiD
  • Senior Member
  • PipPipPipPip
  • 407 posts
Posted 11 January 2017 - 03:47 PM
Or should I just lower my perch an inch or two? which would be 5-6 inches below the gland nut
68 510     K i D
        :baby:
#64 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,553 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '96 Pathfinder, too much other shite
Posted 11 January 2017 - 05:45 PM
The actual adjustability is meaningless. You can get just as low by just moving your perch as far down as possible as you can with an adjustable setup that lowers the spring the same distance. Lowering is about total strut height in this case. How you reduce that total strut height isnt important.
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#65 That4doorKiD
That4doorKiD
  • Senior Member
  • PipPipPipPip
  • 407 posts
Posted 11 January 2017 - 10:05 PM
I will be lowering my perch then. Thanks for that info!
68 510     K i D
        :baby:
#66 banzai510(hainz)
banzai510(hainz)
    L motor God
  • Senior Member
  • 15,360 posts
Posted 12 January 2017 - 09:10 AM
key is what offset rim/tires you use.
On 510 struts I used the same perch weld on my t3 kit as the tire would hit the collar.as I had +25mm 15x7 and its almost touches the strut.
on 280 zx struts being 3/4 INNER, I think you can get the collar below using a 0 offset rim
Throw on some Weber sidedrafts, Rising Sun hood.... call it good
#67 q-tip
q-tip
    shark-tip
  • Senior Member
  • 14,710 posts
  • Cars:72 ka'd 4dr 76 620KC
Posted 12 January 2017 - 10:26 AM
I have +17 offset 6.5" wide wheel on the from of my 510 with zx struts and they're so close that the flex in the tire has rubbed the paint off of the strut tube. With the Zx hubs 0 offset is almost a must.
I yeald to the wisdom of Q on this one.
Fuck!!!!!!!! I guess QTip was right...
