Master-O-Turbonics Posted April 22, 2010 Report Share Posted April 22, 2010 Hey guys.... I may be new to Ratsun but not new to Datsuns... I have a good amount of knowledge around the L series engine(mostly L6 engines), so I figured I would use L series parts, among other parts, to build my powerplant. Just showing what I'm doing here. The parts I have gathered so far: Pistons, reconditioned rods, reconditioned crankshaft (.5mm on mains, .25mm on rod journals), fresh bearings. **EDIT** Now using a closed chamber A87 head** This top end is about to get worked completely over... fairly fresh Z24 head with some 45mm individual throttle bodies, prepped rockers, port cleanup, new valve guides and I'm looking around for some better valve springs. I'm prepping an L20B block to house this assembly. Should be a good little torque monster. Quote Link to comment
nismo dr Posted April 22, 2010 Report Share Posted April 22, 2010 Vroom, can't wait to watch this build, any renderings of the car you'd like to share? Quote Link to comment
Skib Posted April 22, 2010 Report Share Posted April 22, 2010 I dig it :cool: welcome to Ratsun any renderings of the car you'd like to share? second! Quote Link to comment
sssr20det510 Posted April 22, 2010 Report Share Posted April 22, 2010 wheres pics of the car :D Quote Link to comment
Master-O-Turbonics Posted April 22, 2010 Author Report Share Posted April 22, 2010 Vroom, can't wait to watch this build, any renderings of the car you'd like to share? This is a very early, very rough sketch.... Physical parts layout.... I haven't really seen many L series 4 cylinder based builds that made any kind of real power other than the Turbo-Tom built L20B engines of fame, and one aussie built N/A engine that involved changing the angle of the intake valves. Hopefully that is about to change. This bottom end is good for way more horsepower than I will need (350+hp), but can I get the top end to flow enough? Quote Link to comment
nismo dr Posted April 22, 2010 Report Share Posted April 22, 2010 That's pretty sexy looking. :thumbup: I love the baggage deals. Quote Link to comment
Master-O-Turbonics Posted April 22, 2010 Author Report Share Posted April 22, 2010 That's pretty sexy looking. :thumbup: I love the baggage deals. Thanks! I always liked hot rods, but not the fact that they weighed a ton and handled horribly, so I decided to design my own car. Quote Link to comment
Skib Posted April 22, 2010 Report Share Posted April 22, 2010 whats the plan for the suspension? Quote Link to comment
fisch Posted April 22, 2010 Report Share Posted April 22, 2010 VERY PSYCHED ABOUT THIS! Welcome and document everything! Quote Link to comment
DISLEXICDIME Posted April 22, 2010 Report Share Posted April 22, 2010 Z24 heds flow as much as a stock l20 head why are you using that? Quote Link to comment
Master-O-Turbonics Posted April 22, 2010 Author Report Share Posted April 22, 2010 whats the plan for the suspension? 4 wheel independent...unless I get a deal on this quick change rear end that I'm looking at. Upper control arms will be circle track stuff, first generation Z car front spindles are modified for upper control arms with toyota 4x4 brakes, 7/8" master cylinder, and a brand new series 1 240Z brake booster (already have that Z stuff laying around). If I decide I need more braking, Z32 brake stuff will go on there. The race wheels are 15x8 diamonds and will have 225/45R15 hoosiers mounted on them. Quote Link to comment
Master-O-Turbonics Posted April 22, 2010 Author Report Share Posted April 22, 2010 Z24 heds flow as much as a stock l20 head why are you using that? There won't be much "Z24" left when I finish welding. Z24 heads aren't that bad once you can fix the sharp inner radius, plus packaging of the engine is better with a crossflow design, since I have a narrow engine bay. Plus I like the idea of having 2 plugs per cylinder for a boosted engine. Ignition will have coils for a wasted spark distributorless 8 cylinder engine, although I won't be wasting the spark. ;-) Did I mention the 2006 Holset sitting in my closet? Quote Link to comment
DISLEXICDIME Posted April 22, 2010 Report Share Posted April 22, 2010 There won't be much "Z24" left when I finish welding. Z24 heads aren't that bad once you can fix the sharp inner radius, plus packaging of the engine is better with a crossflow design, since I have a narrow engine bay. Did I mention the 2006 Holset sitting in my closet? Ahhh I thought you where trying to do this na I was going to say you are crazy lol Quote Link to comment
Master-O-Turbonics Posted April 22, 2010 Author Report Share Posted April 22, 2010 Ahhh I thought you where trying to do this na I was going to say you are crazy lol There isn't really a good datsun N/A head to use on the old blocks without spending way too much time working the intake side of things, but a KA24DE head would work fine if you could get enough bore out of the block to give clearance for the valves. I like having an engine that can be rebuilt one or two times without having to get a new block each time because of a rediculously huge bore. (not saying datsun heads suck, but far from ideal as there are much more sucky heads out there) I'm using a very conservative bore and a fairly long stroke on this engine. Torque is very important to me in this car. Good streetability in low RPMs but should flow well enough for higher RPM boost (limited until I find some better valve springs that will work in a Z24 head). Obviously this is not an all-out 10,000RPM race engine, but its not a slug of a truck engine either. Quote Link to comment
SurgeL320 Posted April 27, 2010 Report Share Posted April 27, 2010 I have my doubts on this, no offense. From the sketch to the final product is an insane amount of work, time,and money no matter how good you are and thats not even counting the tools you will need for the body work. But if your like me telling you it cant be done will only motivate you more. Good luck on this Quote Link to comment
mklotz70 Posted April 27, 2010 Report Share Posted April 27, 2010 Seriously!!! I want to see lots of pics on this project. Like the mod to the struts to use an upper control arm. Looking forward to seeing what kind of tools and skills you have to bring this about. Awesome!! I say go for it!!!! I love the design!! Where is SE? Quote Link to comment
motavated Posted April 27, 2010 Report Share Posted April 27, 2010 WEEEEEEEEE!!!!!!! Quote Link to comment
datzenmike Posted April 27, 2010 Report Share Posted April 27, 2010 You don't say much about the motor except L20B block so that must be a Z22 crank, 6" rods? Pistons aren't L or Z nor KA24Es so must be custom. So how much larger than the stock L20B's. The turbo will go a long way to correcting the Z head's poor breathing. Quote Link to comment
Master-O-Turbonics Posted April 27, 2010 Author Report Share Posted April 27, 2010 Seriously!!! I want to see lots of pics on this project. Like the mod to the struts to use an upper control arm. Looking forward to seeing what kind of tools and skills you have to bring this about. Awesome!! I say go for it!!!! I love the design!! Where is SE? Here is another little toy I picked up from a friend of mine. Spins smooth, no play. Quote Link to comment
racerx Posted April 27, 2010 Report Share Posted April 27, 2010 You can build up an L series engine but by that time, you could have gone to like a KA or SR motor and probably have spent less. I thought about building up an L series engine and could not make up my mind with either KA or SR and just decided to stick with an L18 rebuilt engine....not much more power than an L16 but it's just a DD and suits me fine... Quote Link to comment
Master-O-Turbonics Posted April 27, 2010 Author Report Share Posted April 27, 2010 You can build up an L series engine but by that time, you could have gone to like a KA or SR motor and probably have spent less. I thought about building up an L series engine and could not make up my mind with either KA or SR and just decided to stick with an L18 rebuilt engine....not much more power than an L16 but it's just a DD and suits me fine... I got all my parts for very cheap, and this isn't going in a daily driver. Plus it helps that I have access to a machine shop to machine my little bits. Not everything I do is for the best power/$ ratio. I have a friend that is practically giving away a perfect low mile SBF 302... that would have beat the pants off of any datsun engine for the power/$ ratio. Lets just say this is a bit of an experiment. Quote Link to comment
]2eDeYe Posted April 27, 2010 Report Share Posted April 27, 2010 I think your crazy.... ...but I like it. :cool: Quote Link to comment
Datsun fan Posted April 27, 2010 Report Share Posted April 27, 2010 Building a hot rod from a scratch ???!!! Are you kidding ??!! 350+ hp !!!!! How much of torque ? which tranny can take it ??!! Designing and fine tuning suspension??!! You have just opened the gate of HELL . Good luck Quote Link to comment
Master-O-Turbonics Posted April 28, 2010 Author Report Share Posted April 28, 2010 Building a hot rod from a scratch ???!!! Are you kidding ??!! 350+ hp !!!!! How much of torque ? which tranny can take it ??!! Designing and fine tuning suspension??!! You have just opened the gate of HELL . Good luck Haha! I'll be more than overjoyed if this motor ever made that kind of power. The bottom end is being built stout to support 350+hp. Will this head ever flow enough for 300hp? I doubt it. Overbuild the bottom end to last, then build the head to flow as much as possible and you won't outgrow your strong bottom end. Planning on using a $50 240sx tranny in an L series bell housing. Maybe one day an S15 6 speed if I can figure out how to get it mounted in that bell housing. I have a basically new SPEC clutch left over from my Z car stuff that should hold 300hp, considering the weight of this car. Every day I work on race cars. Sunrise to Sundown. I see what works and what doesn't. Like I said, this is an experiment. I have no idea how much power this engine will make, but it better make at least 180hp. LOL Quote Link to comment
Datsun fan Posted April 28, 2010 Report Share Posted April 28, 2010 I suggest kindly you visit Drive train section and read "The mother of all projects" Every day I work on race cars. Sunrise to Sundown. I see what works and what doesn't. You only see what your eyes want to see ....... I hope you are not FROZEN :D . Hasta luego Quote Link to comment
