compression Posted March 22, 2010 Report Share Posted March 22, 2010 OK guys here is the story. I built this 610 from the ground up a few years ago. Many have seen it at the Canby show these last few years, or circulating the web. http://home.comcast.net/~suchy3072/610build/Page%201.htm Last fall I decided it was time to sell it, new opportunities were presenting themselves. http://home.comcast.net/~suchy3072/Page610/610sale.html After a few months on the web... http://bringatrailer.com/2009/09/09/bat-exclusive-1974-datsun-610-hot-rod/ It finally sold to a guy named Jerry in the Norther California area (Ratsun user: datluvr). Dont worry this car will not fade away into history, Jerry is active in the datsun community and will give it a great home. As part of the sale, he opted for the turbocharged option. I had offered this as something to help sweeten the deal and also to put the icing on the cake. The car needed the power to go with the looks. We agreed on a price and I got to work. Over the past 2-1/2 months I have been hard at work on the project and thought I would make thread about it. Turbocharging a KA24DE is nothing new, so there is plenty of information out there about the in's and out's of the job. The goal was 300WHP on the stock engine. The car dyno'd at 154HP at the wheels in N/A form, we the goal was to double that. The 610 is blessed with a larger-than-a-510 engine bay, which helped out a lot! The setup: The buyer wanted the best of the best for turbochargers, so we decided on a Garrett GT2871R. This is high-flowing, quick spooling, water cooled, ball bearing turbocharger. Reliable and powerful, perfect! All the parts were ordered and work was stared. engine management was going to be handled with an AEM FI/C-6 piggyback. This was the most cost-effective and fitting solution for the job. A full-blown stand-alone would be overkill...and very expensive. By the way, as I write this, the car is up and running with the turbocharger system. This all happened between mid-January to mid-March. STEP 1: Find an intercooler and mount it. The intercooler chosen was a tube/fin style. This was chosen because it allows more ambient air to pass through it, thus not starving the radiator of cool air. And, it will cool plenty for 10-12psi of boost pressure. After some fiddling, it was mounted in place that did not require any modification to the grille or lower valence. It did however require enlarging some holes in the core support to pass the pipes through. Also, it left plenty of open area for the radiator. STEP 2: Oil Pan. The oil pan was pulled off the engine and cleaned. Then I welded a -10AN fitting on the side for the turbo oil return. The pan was cleaned again, paint was touched up, and it was re-installed. STEP 3: Exhaust manifold. The exhaust manny was ordered from JGS turbo. They delivered a log-style maniold without the turbo flange placed. I was going to do this myself. With the manifold in hand, I was able to position the turbo exactly where I wanted it. I did consider a top-mount option, but I could not find a turbo position that I would be happy with, it came very close to the brake master cylinder and also the hood. I went with a bottom mount setup, this kept the heat of the turbo away from any sensitive areas. I tacked the turbo flange in place and then finish-welded it. This was then followed up with a few hours of grinding and sanding, to open up a hole in the manifold for the flange. When it was done, it was all free-flowing smooth goodness. STEP 4: Piping. It took a few tries and many orders of elbows from www.siliconeintakes.com to come up with the best pipe routing. I chose a Synapse Engineering synchronic BOV. Recirculation of the BOV was going to be necessary. All charge pipes are 2.5" aluminum mandrel bent. After all the routing was confirmed, I welded up the pipes. After all the piping was mocked up, everything was sent out for powder and ceramic coating. Turbo fully assembled ready for final bolt-up I made a custom catch can and routed all the PCV lines to it: Oil supply Tee for turbo. Oil return Gauges (boost and wideband) (((I will update more as I have time))) Quote Link to comment
datzenmike Posted March 22, 2010 Report Share Posted March 22, 2010 How did you mount the projecktor headlight on the battery side? Also, I'm no turbophile, but wouldn't it be better to draw cool air from in front of the rad? Quote Link to comment
JDM510 Posted March 22, 2010 Report Share Posted March 22, 2010 its always nice to open a thread full of WIN!!!! :D Quote Link to comment
MicroMachinery Posted March 22, 2010 Report Share Posted March 22, 2010 Dude, that 610 is honestly one of the coolest Datsuns I've ever seen. Makes me sick. :lol: Quote Link to comment
INDY510 Posted March 22, 2010 Report Share Posted March 22, 2010 This has always been my favorite datto.............. now it is even better.......... OMG SO much WIN One question: I have a KA710 and I can't find a sway bar that fits around the T/C rod mounts and the front sump I see you are running a MadDat 180b sway bar and it looks like a perfect fit....... Is it a custom bar or do they sell those? How much? and how much was shipping? How many weeks till it arrived? EDIT: I found a 180b conversion sway bar on their website..... is this what you got?: http://www.maddat.com.au/suspension-parts.php Quote Link to comment
bonvo Posted March 22, 2010 Report Share Posted March 22, 2010 well im glad to see it leaving with one last hoorah i still couldnt bring myself to sell it but im glad to see its gonna be bitchin when it goes Quote Link to comment
zerow Posted March 23, 2010 Report Share Posted March 23, 2010 Compression, FTW! This 610 only gets better and better. Urge the new owner to join ratsun. We cannot watch this girl ride off into the sunset without some kind of updates... Quote Link to comment
Creepy Cruiser Posted March 23, 2010 Report Share Posted March 23, 2010 Very nice Aaron! Quote Link to comment
610SSS Posted March 23, 2010 Report Share Posted March 23, 2010 Cant believe u sold this. Quote Link to comment
zerow Posted March 23, 2010 Report Share Posted March 23, 2010 This has always been my favorite datto.............. now it is even better.......... OMG SO much WIN One question: I have a KA710 and I can't find a sway bar that fits around the T/C rod mounts and the front sump I see you are running a MadDat 180b sway bar and it looks like a perfect fit....... Is it a custom bar or do they sell those? How much? and how much was shipping? How many weeks till it arrived? The one from a 610 should closely match your 710. I need to contact a friend to be sure. And if that's the case, then you can use this: http://www.racetep.com/datsunsusp.html Second item down on the page... Quote Link to comment
compression Posted March 24, 2010 Author Report Share Posted March 24, 2010 This has always been my favorite datto.............. now it is even better.......... OMG SO much WIN One question: I have a KA710 and I can't find a sway bar that fits around the T/C rod mounts and the front sump I see you are running a MadDat 180b sway bar and it looks like a perfect fit....... Is it a custom bar or do they sell those? How much? and how much was shipping? How many weeks till it arrived? EDIT: I found a 180b conversion sway bar on their website..... is this what you got?: http://www.maddat.com.au/suspension-parts.php Yes, 180B conversion sway bar from Maddat. I think after shipping, It was about $300. I dont remember how long it took to arrive, but it wasnt too long. I think I paid extra for air freight. It is almost a perfect fit, it rubs ever-so-slightly on the T/C plates. Quote Link to comment
compression Posted March 24, 2010 Author Report Share Posted March 24, 2010 Cant believe u sold this. You didnt think anyone would buy it? :P Quote Link to comment
510six Posted March 25, 2010 Report Share Posted March 25, 2010 That is a very clean setup, and it should supply ample passing power. Quote Link to comment
Danfinny Posted March 25, 2010 Report Share Posted March 25, 2010 That is a very clean setup, and it should supply ample passing power. HAHA yea.... i don't know if ample is the word for it though....more like wtf was that as you fly by someone... Quote Link to comment
datsun 160J SSS Posted March 26, 2010 Report Share Posted March 26, 2010 very clean work great to see someone put the time in to make it right .not like some i have seen on ratsun just hack it up and go . Quote Link to comment
compression Posted March 26, 2010 Author Report Share Posted March 26, 2010 Just finished wiring up the AEM FI/C-6. It is a great alternative to full stand-alone for people that want tune-ability of there EFI without the huge cost. It is a piggy back that works with the stock computer. Cost about $350 or so, totally worth it in my book. A little tricky to wire it up, but most of these older nissan (from the 1990's) ECU's are pretty basic and dont complain much. I will do a write-up on KA-T.org on how to wire a FIC to a 1995 KA24DE, if anyone wants to duplicate it. My 700cc injectors should be arriving soon, then it is time to hit the street and do some tuning (not at the same time of course, thats worse than texting and driving!). Also, part of this swap was to pull out the 3.54 viscous diff and put in a r160 (subaru) 3.7 clutch LSD, so now it will do a proper burn out (the viscous never worked correctly...) Of course there will be a vid, and if I have time, might take her out one evening for a round of glamor shots. I edited the first post to include the Ratsun screen name of the guy who bought the car: datluvr , he said it was cool. So dont worry, it will stay in the community! Quote Link to comment
78kingcab Posted March 26, 2010 Report Share Posted March 26, 2010 awsome freaken datto man...you built a dream there,lucky new owner.....cant wait for a video..... :cool: Quote Link to comment
510six Posted March 28, 2010 Report Share Posted March 28, 2010 HAHA yea.... i don't know if ample is the word for it though....more like wtf was that as you fly by someone... It depends on your perspective. BTW super clean setup Quote Link to comment
69FJWagon Posted April 7, 2010 Report Share Posted April 7, 2010 Aaron...um...ya updates PLEASE..! :D Cant wait for Datluvr to get this thing home so I can take a ride in it :cool: Clayton Quote Link to comment
compression Posted April 7, 2010 Author Report Share Posted April 7, 2010 Aaron...um...ya updates PLEASE..! :D Cant wait for Datluvr to get this thing home so I can take a ride in it :cool: Clayton I test drove it with the stock computer and the AEM FIC inactive and with the stock injectors. Just took it easy putting around the neighborhood. Everything went well, so I got home and installed the 700cc injectors, then it stated raining. so now the tuning needs to start. It is basically sitting in the garage waiting to be tuned. We are waiting for it to F'in stop raining so we can get some street time with it. Will update as I make progress. This thing will get dynoed, so I will post that when I have it. Quote Link to comment
PurePontiacKid Posted April 7, 2010 Report Share Posted April 7, 2010 I love it. The black wrinkle coating makes everything look factory! I can't wait to see what else is in store! Quote Link to comment
compression Posted May 23, 2010 Author Report Share Posted May 23, 2010 UPDATE! The car is now tuned! Tuning was done with the stock ECU and an AEM FI/C-6 piggyback. The great thing about this type of setup is that the stock computer controls the driveability, cold start, etc, then when the boost builds up, the FI/C steps in and makes things work. Best of both worlds. I would recommend the FI/C to anyone looking for an affordable engine management solution. The car performed great on the dyno. After about 3 hours of tuning and gradually raising boost, we hit 295Hp at the wheels at 11psi! Here is the dyno chart: You can see on the chart the graph for the original L20B, then the normally aspirated KA, and now the turbocharged KA. After the dyno, I babied it home (it was raining) and it has been sitting in the garage ever since. I am scared to death to drive it at the full boost level.... it was really fast at 7 psi, spinning the tires into 3rd gear, and I now I cant even imagine.... But I have to take it out to get some more video footage, SO I better just nut up. I am working on a video, should have it soon. Jerry should be taking delivery of the car soon. Quote Link to comment
thisismatt Posted May 23, 2010 Report Share Posted May 23, 2010 Very nice install - something to be proud of. I'm a little surprised at pushing 300hp on the stock bottom end, but I guess if it goes it's not that big of a deal :lol: Quote Link to comment
lynchfourtwenty Posted May 23, 2010 Report Share Posted May 23, 2010 wow... an your selling it? haha wtf? welll great work! matt: 300 on the stock bottom end is nothing new.. its all about gettin a good bottom end to begin with an not starting out with some 250k pos lol Quote Link to comment
510six Posted May 23, 2010 Report Share Posted May 23, 2010 You can see on the chart the graph for the original L20B, then the normally aspirated KA, and now the turbocharged KA. After the dyno, I babied it home (it was raining) and it has been sitting in the garage ever since. I am scared to death to drive it at the full boost level.... it was really fast at 7 psi, spinning the tires into 3rd gear, and I now I cant even imagine.... But I have to take it out to get some more video footage, SO I better just nut up. I am working on a video, should have it soon. Jerry should be taking delivery of the car soon. I would love to see the video. Quote Link to comment
