philcas1987 Posted March 18, 2010 Report Share Posted March 18, 2010 L18 rebuild parts. - new 60 over clevite pistons - hi tech 60 over cast rings - hi tech standard main bearings - hi tech standard rod bearings - new felpro head gasket - new misc l series gaskets - slightly used timing chain set. was on an l18 for about 5 miles. head gasket blew. ill take no less than $130 for it! Link to comment
ariascarlos1990 Posted March 18, 2010 Report Share Posted March 18, 2010 would this kit work with an l20? I'd have to run 94 octane huh? Link to comment
datzenmike Posted March 18, 2010 Report Share Posted March 18, 2010 Sure will but you will have to overbore the block. Box says 0.030 for pistons and rings. I assume that's in inches so this is about 3/4 of a mm. You would have to measure the pistons and bore to whatever size they are. A 1mm over piston 0.0394" would give you a 1997cc motor and with the L18 piston dish and an open chamber head, a compression of 9.444 Link to comment
ariascarlos1990 Posted March 18, 2010 Report Share Posted March 18, 2010 Thanks Mike! But, if I use a peanut head I can run pump gas right? Link to comment
datzenmike Posted March 19, 2010 Report Share Posted March 19, 2010 10.9 maybe a hair less if under a mm oversize. I guess good premium gas and peanut ... would ... work. Link to comment
sssr20det510 Posted March 19, 2010 Report Share Posted March 19, 2010 sinnful has a l18 short block needs 1 rod its mia Link to comment
banzai510(hainz) Posted March 24, 2010 Report Share Posted March 24, 2010 whats the dish on those pistons? and where is it made? Looks more like L20 pistons cause of the deep dish. L18s barely have a dish. those are .030 over piston and ring set. .060 would be 1.5mm overbore. .75mm =.030 good price on those. But bet they are made in taiwan. Not that it matters that much for s stock type motor Link to comment
philcas1987 Posted March 25, 2010 Author Report Share Posted March 25, 2010 whats the dish on those pistons? and where is it made? Looks more like L20 pistons cause of the deep dish. L18s barely have a dish. those are .030 over piston and ring set. .060 would be 1.5mm overbore. .75mm =.030 good price on those. But bet they are made in taiwan. Not that it matters that much for s stock type motor Thanks for the correction hainz! The are .030 over. I haven't looked at them in a while I just assumed. Pistons are made in the usa! I'm going to golden gardens on Sunday. If any one up north wants this let me know. Link to comment
hang_510 Posted March 25, 2010 Report Share Posted March 25, 2010 sinnful has a l18 short block needs 1 rod its mia i have a set avail. Link to comment
fastdadd Posted March 26, 2010 Report Share Posted March 26, 2010 does hello kitty approve of this sale Link to comment
ariascarlos1990 Posted March 26, 2010 Report Share Posted March 26, 2010 whats the dish on those pistons? and where is it made? Looks more like L20 pistons cause of the deep dish. L18s barely have a dish. those are .030 over piston and ring set. .060 would be 1.5mm overbore. .75mm =.030 good price on those. But bet they are made in taiwan. Not that it matters that much for s stock type motor So these are L20 pistons? Link to comment
philcas1987 Posted March 26, 2010 Author Report Share Posted March 26, 2010 So these are L20 pistons? Don't know. I ordered them for a l18. They are dished. Us spec l18 I would say. Link to comment
banzai510(hainz) Posted March 26, 2010 Report Share Posted March 26, 2010 look like made in USA on the box. If L18 I might want them myself but I have a Sealed Power set new in box already also. If truly a L18 set this could be good for a L20. somebody should get these. Link to comment
ariascarlos1990 Posted March 26, 2010 Report Share Posted March 26, 2010 look like made in USA on the box. If L18 I might want them myself but I have a Sealed Power set new in box already also. If truly a L18 set this could be good for a L20. somebody should get these. So would these piston be compatible with l20 rods? what about the bearings and seals will they work for the l20 to? Link to comment
banzai510(hainz) Posted March 26, 2010 Report Share Posted March 26, 2010 main bearings are a different size on L20s rods and ring, pistons are the same on L18/20 as standard size is 85mm bore Link to comment
alwaysshocking Posted March 27, 2010 Report Share Posted March 27, 2010 How much total shipping to 92683. Are you going to the eaglerock swap meet? Link to comment
philcas1987 Posted March 29, 2010 Author Report Share Posted March 29, 2010 Bump! $130 shipped. Link to comment
78kingcab Posted March 29, 2010 Report Share Posted March 29, 2010 how much for you to come over and put it in my l18......good price free bump Link to comment
philcas1987 Posted March 31, 2010 Author Report Share Posted March 31, 2010 $100 local. $130 shipped!. Link to comment
philcas1987 Posted April 3, 2010 Author Report Share Posted April 3, 2010 Bump! Anyone? Link to comment
ptown green Posted October 18, 2010 Report Share Posted October 18, 2010 Still got all this stuff? Im interested if so.. Link to comment
