Little Red Wagon...
  • Replies 688
  • 3 weeks later...
  • 1 month later...
Finished diff side plumbing last night... Had to improvise and change just about everything from the previous, factory like routing. With the new found axle travel range combined with the tight component configuration, line placement was rather critical. In addition, I decided to continue my semi tucked, brake line system under the hood to the rear axle as well. :)
Joel, with the pinion centered like that, it seems the housing favors one side, was this true when you shortened it?, so one axle, is in fact shorter than the other?? or is this an optical illusion?
and also did it force  one of the angled links to be shorter than the other?
and does the l series driveshaft bolt to the rx7 pinion?
  • 2 weeks later...
I just reread this entire thread over coffee this morning.  I've been needing motivation and inspiration.....thanks for both of those things Joel.
I really appreciate your  amazing work and the vision you have for the car, it's all so impressive!
Thanks for sharing the experience.....
  • 10 months later...
  • 7 months later...
