Short or Long struts?
haubstr
  • Replies 8
buy the springs for the long strut. no matter what strut length you have.
The long strut springs they list will be shorter. Thats what you want and you still might have to cut a 1/2 a spring off to get the look you want.
Believe me!!!!!!!!
photo shows weld at spring perch to bottom of the tube this is a long strut which is the most common 11.5in
there are 11 and 10.5 inch(68/69)
Yah, but I'm cheap and the re oiled dampers are great. I think I'd drop to 25W or so with the 200lb springs, but, I need to find some softer rear shocks first.
Just pick up some chicks to counter balance the spring stiffness, thats what Hainz does. He likes them BIG so it only takes on chick :D
