lynchfourtwenty Posted December 12, 2009 Report Share Posted December 12, 2009 (edited) could i run it on 92 octane? what would the compression be? im seein like just over 10.1 or so.. ? also would i have to have valve reliefs cut into the pistons or no? Edited December 12, 2009 by datzenmike Quote Link to comment
DISLEXICDIME Posted December 12, 2009 Report Share Posted December 12, 2009 if i remember right no. the comp is to high for pump gas espeacialy if the head has ben shaved at all go use the ozdat engine utility. it will tell you Quote Link to comment
zed Posted December 12, 2009 Report Share Posted December 12, 2009 (edited) http://www.rbracing-rsr.com/compstaticcalc.html I'm no expert, but I find accurately calculating the compression ratio is a very interesting part of engine building. Not difficult either. I'm running over 11:1 on 95 octane - with no problems (Hainz said my HG is gonna blow soon - but she's done 5000miles already :D ). My motor is a peanut head L18 with L28 flat tops. No need for valve reliefs. My closest piston to valve clearance measured about .060". It seems from my own experience and what I've read on Ratsun that this combination is unusually resistant to knocking. Bear in mind that 'squish' is critical to preventing knock; try to have deck clearance around .030 - .040". Edited December 12, 2009 by zed Quote Link to comment
datzenmike Posted December 12, 2009 Report Share Posted December 12, 2009 (edited) L20B with 86mm flattops = 1997cc Open head......... 10.11 Closed head....... 10.87 Also a peanut head on stock dished pistons does not have the same quench area a flattops. Flattops have the best advantage as the whole area of the piston top covered by the head is the 'pinch' area. Stock L20B only have a 1cm wide ring around the piston edge that is pinched. Edited December 12, 2009 by datzenmike Quote Link to comment
BRE_dAtSuN Posted December 12, 2009 Report Share Posted December 12, 2009 Hey datsunmike I have l20b with 87mm flattop pistons on an open chambered u67.. I only get 91 here in cali unless I want 101 but there's only like 4 places I know that has it...but my ? To u is wat do you think my compression ratio is at? Quote Link to comment
datzenmike Posted December 12, 2009 Report Share Posted December 12, 2009 Hey datsunmike I have l20b with 87mm flattop pistons on an open chambered u67.. I only get 91 here in cali unless I want 101 but there's only like 4 places I know that has it...but my ? To u is wat do you think my compression ratio is at? Think?..... Hell, I'll work that out and we'll know for sure!!! L20B with 87mm flattops with U-67 open chamber head would be a 2,043.9cc motor with 10.292 compression. This assumes a standard head gasket crushed thickness of 1.2mm and an un milled head. Quote Link to comment
Dudeman Posted December 12, 2009 Report Share Posted December 12, 2009 I'm running over 11:1 on 95 octane - with no problems (Hainz said my HG is gonna blow soon - but she's done 5000miles already :D ). My motor is a peanut head L18 with L28 flat tops. No need for valve reliefs. My closest piston to valve clearance measured about .060". It seems from my own experience and what I've read on Ratsun that this combination is unusually resistant to knocking. Bear in mind that 'squish' is critical to preventing knock; try to have deck clearance around .030 - .040". Are you sure about that compression ratio? All of the calculating I've done comes out to 10.1:1, unless you've had your head or deck milled. Quote Link to comment
BRE_dAtSuN Posted December 12, 2009 Report Share Posted December 12, 2009 Think?..... Hell, I'll work that out and we'll know for sure!!! L20B with 87mm flattops with U-67 open chamber head would be a 2,043.9cc motor with 10.292 compression. This assumes a standard head gasket crushed thickness of 1.2mm and an un milled head. I put a metal head gasket and arp studs but im not sure of the thickness I have to check again Quote Link to comment
banzai510(hainz) Posted December 12, 2009 Report Share Posted December 12, 2009 you have good high octane gas!!!!!!!It will work but I suggest against it as a daily driver myself Quote Link to comment
lynchfourtwenty Posted December 12, 2009 Author Report Share Posted December 12, 2009 i run 92 octane from chevron in the truck already, so as long as im not buyin race gas i dont care about the gas price.. so mike, do you think i could get away with this? Quote Link to comment
Jason Posted December 12, 2009 Report Share Posted December 12, 2009 You'll have to run premium with this setup IMHO. My by buddy runs this and runs 94 octane with as much timing as he can without pinging. Set it up and back off timing with premium until the pinging stops and you should be OK. Mind, you better have a good cooling system to get this to work well! Quote Link to comment
lynchfourtwenty Posted December 12, 2009 Author Report Share Posted December 12, 2009 awesome, so i could run premium an maybe an octane booster an be ok... i dont drive the truck often, an it hauls shit on ocasion but not all the time.. i have a 3 year old (was new when i got it) 720 radiator, the guy at the radiator shop said it was a tri-core, but idk.. however the trucks never over heated on me the way it is.. i could easily put an electric fan on.. Quote Link to comment
datzenmike Posted December 12, 2009 Report Share Posted December 12, 2009 If you have the head just slap on and try it. If you get it cheap try it and if you don' t like it you can always sell for what you paid. Don't know how good US 92 gas is. If you have to bore and add the pistons and then find it doesn't work,... well all I can say is that's a lot of expense and work. Quote Link to comment
lynchfourtwenty Posted December 12, 2009 Author Report Share Posted December 12, 2009 :( i just wanna do something different ya know.. but i dont wanna waste money.. im gonna do some pricing an stuff an talk with hrh an see what we can figure out.. would be a bad little motor tho eh? Quote Link to comment
datzenmike Posted December 12, 2009 Report Share Posted December 12, 2009 Sounds like a fine build. BTW was the A-87 cam the same as the L20B cam? Quote Link to comment
Jason Posted December 12, 2009 Report Share Posted December 12, 2009 I don't think it's a good thing to need Octane booster, I'd try to stay under that point if I could. Remember if you're under load (ie carry stuff) the pinging will get worse so you'll have to back off timing even more. The cooling's important 'cause heat aggravates the pre detonation. Quote Link to comment
lynchfourtwenty Posted December 12, 2009 Author Report Share Posted December 12, 2009 Sounds like a fine build. BTW was the A-87 cam the same as the L20B cam? not sure man?? thats a good question.. what are these http://www.google.com/products?q=l20b+cylinder+head+spacer&sourceid=ie7&rls=com.microsoft:en-us:IE-SearchBox&oe=&um=1&ie=UTF-8&ei=fyUkS7CoNY_WtgPuwYThDg&sa=X&oi=product_result_group&ct=image&resnum=1&ved=0CBgQzAMwAA ? i cant find out how much they "space" it out tho.. an do you have to use 2 headgaksets? or no??? Quote Link to comment
lynchfourtwenty Posted December 13, 2009 Author Report Share Posted December 13, 2009 I GOT IT!!!!! ok after playin around on that ozdat engine builder thing i think i figured out a good combo.. ok so.. SR20DE flat top pistons = 86mm bore pin height is 32mm but the wrist pin is 22mm Z22E rods Length 149.5 Piston End Bore 21 Piston End Thickness 25.4 Big End Bore 53 Big End Thickness 26.8 if its possible to machine the piston end of the rod to 22mm from 21mm i could use the l20b crank.. using a 1.2mm head gasket?? not sure if thats correct?? and a peanut head i get 8.6 compression.. is that right for the gasket thickness? Quote Link to comment
lynchfourtwenty Posted December 13, 2009 Author Report Share Posted December 13, 2009 just gettin creative.. lol Quote Link to comment
DISLEXICDIME Posted December 13, 2009 Report Share Posted December 13, 2009 remeber where we live lynch weed smoker the temp changes all the time. With my 11.5 . 1 l18 i have to adjust the carbs a few times a year because of the temperature changing the density of the air. slodat also had this problem with his lz20 that was built the same as my l18 . this was with us both running premium. I also tried to use the same rad i used on my 10 to 1 l16 but it did not cool enough for the l18 so i had to put in a aliminun fiero rad . now my car runs to cold lol if i do another l i think i am going to try to do the lz 2.3 Quote Link to comment
lynchfourtwenty Posted December 13, 2009 Author Report Share Posted December 13, 2009 good input mikey, thanks.. Quote Link to comment
datzenmike Posted December 13, 2009 Report Share Posted December 13, 2009 1.2mm is generally considered the crushed gasket thickness. I get 8.66 so good going. You do get a monster -2.95mm deck height which accounts for an added 17cc of additional combustion chamber but with flattops and peanut this works. Could mill the head a bit if you wanted too. Can I quote you on this??? SR20DE flat top pistons = 86mm bore pin height is 32mm but the wrist pin is 22mm Quote Link to comment
lynchfourtwenty Posted December 13, 2009 Author Report Share Posted December 13, 2009 you can if that ozdat site is correct, which im sure it is.. do you think machining the piston end of the rod to accept the 22mm wrist pin would be ok? i was tryin to shoot for close to 9.1 or so maybe a nut hair more.. so ya i bet a shaved head would work ok.. Quote Link to comment
lynchfourtwenty Posted December 13, 2009 Author Report Share Posted December 13, 2009 what made me think about this combo is Fineline has sr20det pistons in his lz motor.. an i was like How'd he doit? Quote Link to comment
69FJWagon Posted December 13, 2009 Report Share Posted December 13, 2009 Hey Lynch that is the same engine set up in Lisas' pick up (521) that Troy built and its been going strong for 12-15000 miles running on Californias shitty ass super 91 octane with no issues, port work done and a Rebello Cam using a 38/38 outlaw weber carb it runs strong just not as strong as with the 44 Mikunis I had on it for a while, still a GREAT COMBO! and Troy figured around 10.2 on the compression Quote Link to comment
