B210 5 spd transmision
  • Replies 24
You would require the FS5W60A transmission. I will ship but I cant let it go for the $200 like the FS5W63A's.... $550 shipped to your door Fed Ex ground.
I will open it up and inspect it before the sale though. I have not seen it in use.
Sorry I didnt see this sooner.
The FS5W63A would also require you to reroute the the clutch lines to the other side of the car.
No big deal though, just a heads up. I belive there is a slave cylinder on one of the 63's that can go with it, if you wish. yours would have the bleeder screw on the bottom if you used it on the 63a.
Some of those 63A units have the clutch fork on the right, some on the left. I think the Rivergate/Morriservice kits need the right. If your's has it on the correct side for the conversion.... the trans CAN be used with a little more clearancing on the tunnel. Read worth lots mo' $$$.
  • 3 weeks later...
  • 3 weeks later...
