mklotz70 Posted June 29, 2014 Author Report Share Posted June 29, 2014 Dave and Steve came over last weekend for both, friday and saturday. We got all the parts finished up......finally!!! Steve took everything back to his place. He'll be doing all the final assembly and sales. Quote Link to comment
guridas2 Posted April 21, 2017 Report Share Posted April 21, 2017 Got some more progress made. Never as much as I want or expect, but still...it's progress My buddy A100addict was over. While I was showing how the motor will spin up to full speed...in reverse.....the flywheel came off!!! Luckily, it nestled itself into the frame piece.....cause it was spinning at around 7000rpm!! It took nearly 10 sec to come to a stop! I was backing up into Dave and he didn't have anywhere to go.......it was rather comical.......after it came to a stop! We played around with some with an idea to put the motor up on top...so it could be a bench model like the other versions. Looks like it can be done and then mounted to a HF grinder stand. Got the flywheel cut off. Got the bearings into one of the pulleys. One of the idlers like this will keep it's crown, the other one got flattened since it will be a platen roller......meaning I'll be grinding directly against it so I don't want any curve. The shaft I got was larger than 5/8".....what a royal pain!! Had to tweak the tailstock to get it to cut the same diameter from end to end. I cut half of the drive shaft...then when I turned it around...I had to tweak the tailstock again...no clue why, but what a pain!! I do believe I'll simply by 5/8" shaft next time!!! I thought I was going to be able to use one of the pulleys as the hub for the secondary drive pulley....didn't work out. So...as I should have done to start with, I made one from scratch. I made it press fit and actually knurled the mounting surface to give it even more grip. It spins pretty darn true. More pics of how it was made are in the machine work thread Hello, I am doing a project with the same magnet DC motor from treadmill you have in the photo. I am trying to find a right v-belt ( it looks like that's 6-rib micro V-belt that you are using) that snugly fits around its 10-grooved sheave like the one in the photo. what are the critical dimensions for that V-belt or better yet can you tell me where you got it ? Also, if possible, do you still have CAD file for that black plastic sheave that you are trying to connect to the other side of V-belt? Thank you very much for your help! Willk Quote Link to comment
mklotz70 Posted April 22, 2017 Author Report Share Posted April 22, 2017 Hello, I am doing a project with the same magnet DC motor from treadmill you have in the photo. I am trying to find a right v-belt ( it looks like that's 6-rib micro V-belt that you are using) that snugly fits around its 10-grooved sheave like the one in the photo. what are the critical dimensions for that V-belt or better yet can you tell me where you got it ? Also, if possible, do you still have CAD file for that black plastic sheave that you are trying to connect to the other side of V-belt? Thank you very much for your help! Willk Sorry, I don't have any info/CAD on any of those parts. The belt and pulleys came with the tread mill. Quote Link to comment
2wheel-lee Posted April 24, 2017 Report Share Posted April 24, 2017 You guys have some fine machinery! My disc sander is one my father made at least 40 years ago. It still runs on the same washing machine motor he scavenged. I've been using this since I was a fairly young boy for plastics, wood, and aluminum (even steel now and then). The top deck unscrews to allow easy removal of the wheel to replace the abrasive disc. While it may appear somewhat rickety with the plumbers strapping, it's been a solid performer through a lot of heavy use - especially when I used to use it at a shop where I worked where we did a lot of wood and plastic fabrication work. These are rear disc brake adapters I made from right-angle aluminum. 2 Quote Link to comment
mklotz70 Posted April 25, 2017 Author Report Share Posted April 25, 2017 Thanks. :) That's awesome! The best tool is the one that works. :) Nice bracket. That must have been one heck of a piece of right angle. Looks like it's at least 1/2" thick....? 2 Quote Link to comment
2wheel-lee Posted April 25, 2017 Report Share Posted April 25, 2017 You got it... 1/2" think angle. I actually fabricating things in somewhat primitive ways. Also as a hobby, I built a number of high-end type bicycle frames doing all my miters by hand with a file. It's not very often do you actually see a rear disc brake setup on a 620 with a truly functional parking brake. 3 Quote Link to comment
mklotz70 Posted April 26, 2017 Author Report Share Posted April 26, 2017 I've got a couple of friends that have done the bike building by hand coping the tubes. At one point, I was going to design a belt grinder that specifically did that. Good job! Getting the e-brake to work is pretty rare. I have yet to see a setup that will fit behind a stock 14" steel rim. Quote Link to comment
