2dat0z9 Posted October 16, 2009 Report Share Posted October 16, 2009 as the tittle says iI wanna swap the differential in my b210. am planning to swap a l20 in it and I would like to have a positive diff. I used the search section and couldnt find nothing... need help please!!!!! Quote Link to comment
THINK OUTSIDE THE BOX 710 Posted October 16, 2009 Report Share Posted October 16, 2009 Ponle uno de un RX7 guey. Quote Link to comment
2dat0z9 Posted October 16, 2009 Author Report Share Posted October 16, 2009 Ponle uno de un RX7 guey. sorry i dnt speak janitor language:lol::lol::lol: el que cale en el jonque no era un posi. era un '88 rx7 Quote Link to comment
DRIVEN Posted October 16, 2009 Report Share Posted October 16, 2009 RX7 is quite a bit wider but cheap. GSL-SE models were LSD with disc brakes. Ford 8.8 is a pretty cheap option but would also have to be narrowed. I know the AE86 Corolla is close to a bolt in and only a little wider. Not sure if there were factory LSD options but there is aftermarket support. Quote Link to comment
b210in Posted October 16, 2009 Report Share Posted October 16, 2009 (edited) you couldnt find it becuase it's hardly ever been done here in the states. you could go a couple of ways. one. swap out your current diff for a later and stronger 75 b210 and up diff. remove the center section and weld the spider gears. now you got posi. this diff will hold the l20b reasonably well. this is a really cheap way to do it and bolt in deal. two. swap the rx7 diff in. you will need to have it re lugged and narrowed to fit the b 210, unless you want to run posittive offsett wheels in the rear then leave it alone. this swap is a little more pricey since re lugging and narrowing could be involved. three. this is what i will be doing to my b210 once i grenade my stock diff. swap in a toyota truck 8 inch diff. most toyota trucks came with either the 7.5 or 8 inch rear end. these diffs have a width of abouth 57 inchces. our b210's have about 51 inches drum face to drum face. i am going to have it narrowed locally, and send the stock shafts to be resplined. about a 300 buck job. posi diffs came in these yota trucks but are really rare. i will be swapping in a center carrier from a four runner, which commonly have posi and lower gears. also worth noting, it's really cheap to get gears for these since all the yota truck guys are always upgrading to lower gears as they go up in tire size, so scoring a really good set of used gears is really easy. there is also a bunch of lunch box lockers and limited slips that are available for this diff should you want to upgrade. and last but not least, they are super strong and will last a long time specially under a four cylinder car. four. if you have unlimited cash, just order up a custom cut to your specs ford nine inch. the problem with this one is that b210's have very limited space to fit such a big pumpkin. you might have to make room. hammer time. you got that GUEY! Edited October 16, 2009 by b210in Quote Link to comment
ggzilla Posted October 16, 2009 Report Share Posted October 16, 2009 I would like to have a positive diff.You can only get a posi (positraction) by swapping in a Chevrolet axle assembly. Or did you mean wheels with positive offset? It'll be difficult to find a stronger rear end that is narrower than the B210's. Quote Link to comment
b210in Posted October 16, 2009 Report Share Posted October 16, 2009 i think he means limited slip Quote Link to comment
2dat0z9 Posted October 17, 2009 Author Report Share Posted October 17, 2009 yea i want a limited slip diff.. i think am gonna go with the welded gears for now since there is a newer b210 at the pick and pull right now, and gonna keep my eyes open for a rx7 differential... i was talking to my cousin about taking the spring leafs off and put a 4 link. any ideas?? and thanks for the info GUEY! Quote Link to comment
ggzilla Posted October 17, 2009 Report Share Posted October 17, 2009 For racing the leaf spring setup is the way to go. For a comfort ride, switch to a coil spring 4-link setup. It's not easy to switch. You can improve drag racing transfer with 4-link but slapper bars are almost as good and super easy to install. Quote Link to comment
datzenmike Posted October 17, 2009 Report Share Posted October 17, 2009 I believe the '75 and up B-210 rear diff. (H-150 vs. the earlier H-145) can also be swapped into the earlier axle housing. Quote Link to comment
b210in Posted October 17, 2009 Report Share Posted October 17, 2009 good. if you are going to get the diff from a later b210, 75 and up, remember to also get the driveshaft. the flange or yoke on the diff is different for 75 and up b210's, your current driveshaft will not bolt up. post pics of what you are doing Quote Link to comment
datzenmike Posted October 17, 2009 Report Share Posted October 17, 2009 Later 310 drive shaft? Quote Link to comment
ggzilla Posted October 17, 2009 Report Share Posted October 17, 2009 Yes, get the matching B210 driveshaft. Also 1974-1982 driveshafts interchange, technically they are different Part Numbers but measure out the same but have a different dust flange which you can cut off or add. Quote Link to comment
iskisenna Posted October 29, 2014 Report Share Posted October 29, 2014 ola todos I'm iski from Malaysia, and i just saw a rear axle from an AE86 come on sale for Malaysian Ringgit 1500 or approx 300 dollars. I'd really like the lsd from the hachi-roku but the rear discs are a bonus. Is it a direct bolt in for the B210? Oh Malaysian B210s run the A 12 engine though i'm swapping it for an a15 soon as well (A15 cos malaysia produced the nissan vanette a15 up til 2009, so aloyta parts are available) Quote Link to comment
datzenmike Posted October 29, 2014 Report Share Posted October 29, 2014 Get out a measuring tape and answer these questions.... The B-210 has rear leaf springs.... does the AE86? Or are they coil spring? Is the AE86 the same width from side to side? Is the AE86 4 or 5 lug bolt rims? Will your rims fit over the AE86's disc brakes? Does the drive shaft size match? How do the emergency brakes connect? Will the differential gear ratio be too high on the AE86. 1 Quote Link to comment
iskisenna Posted October 30, 2014 Report Share Posted October 30, 2014 Hey! Thanks Mike.There's a whole can of worms there. I was looking at swapping out the rims as well. It's just a lil wider. 86 has a 4 link (dammit!) Coilover setup. Shaft size matches the A15 one. E brakes "Aww hell no!". I'm tempted to buy it in preparation for the "whole enchilada swap". Buy a bit there, get the engine ready. Rims etcetc, then BAM! instant (pain in the ass and wallet) sports machine. Quote Link to comment
datzenmike Posted October 30, 2014 Report Share Posted October 30, 2014 A little wide and you can get different off set rims to move the tire back under the fender. Don't forget... the AE86 probably has a terrible gear ratio because of the larger displacement engine. Your B will accelerate like crap and LSD??? The B doesn't have traction problems with 84 horse power. Stick with what you have. Quote Link to comment
iskisenna Posted October 30, 2014 Report Share Posted October 30, 2014 Thanks Mike! You just saved me 300 big ones (or 1500 on my side of the pond) Quote Link to comment
