Pacific coast Datsun Posted October 20, 2017 Author Report Share Posted October 20, 2017 Thanks Gene. Feels good to drive it again. I think the next repair will be doing the front wheel bearings...inner & outer on both sides. 2 Quote Link to comment
Charlie69 Posted October 21, 2017 Report Share Posted October 21, 2017 It runs! What cuased the fusible link to fail? I would carry a roll of fuseable link wire connectors and tools to repair it when it fails again and strands yo on the side of the road again. 99% of the time replacing a bad fuse or a bad fuseable link does not fix the problem because the blown fuse or fuseable link is the result of the problem not the problem. 3 Quote Link to comment
]2eDeYe Posted October 21, 2017 Report Share Posted October 21, 2017 Glad to hear it is on the road again :cool: 1 Quote Link to comment
Pacific coast Datsun Posted October 22, 2017 Author Report Share Posted October 22, 2017 Charlie..the end of the fusible link wire simply came out of the connector..yeah I know lame !! Thanks Redeye..I agree. 2 Quote Link to comment
Charlie69 Posted November 4, 2017 Report Share Posted November 4, 2017 Mark is it still running? 1 Quote Link to comment
Pacific coast Datsun Posted November 14, 2017 Author Report Share Posted November 14, 2017 Yes she starrs right up..idles fine & has decent power. The bad thing is the motor is burning oil / white smoke coming from the exhaust. & now I'll need to get the alternator rebuilt by I can still start it to move it around. 1 Quote Link to comment
Charlie69 Posted November 19, 2017 Report Share Posted November 19, 2017 White smoke is not oil. White smoke is usually water. Do you have anti freeze in it? Quote Link to comment
Pacific coast Datsun Posted November 23, 2017 Author Report Share Posted November 23, 2017 Yes I have a gallon of anti freeze in it & I topped if off with distilled water. The smoke has an odor of oil in it. 2 Quote Link to comment
Charlie69 Posted December 2, 2017 Report Share Posted December 2, 2017 Any progress? Quote Link to comment
gene knight Posted December 3, 2017 Report Share Posted December 3, 2017 pcd: we need updates Quote Link to comment
Pacific coast Datsun Posted December 3, 2017 Author Report Share Posted December 3, 2017 The latest madness is this. I had a dimming headlight issue & had to drive home with no headlights a few weeks back. I tested the output at the back of the alternator & it read between 12 & 14.50 amps . I decided to put the boat alternator on the truck ..I got 2 blocks & the headlights dimmed again & the high beam switch wouldn't even function. I'm thinking & hoping it's just the headlight relay 1 Quote Link to comment
Charlie69 Posted December 3, 2017 Report Share Posted December 3, 2017 Check and clean all grounds. This is 99% of the time the cause of dim lights. Quote Link to comment
Pacific coast Datsun Posted December 3, 2017 Author Report Share Posted December 3, 2017 I'll do that Charlie. The first time this happened I had to turn the lights off to.keep the truck from dying. I also had to.trickle charge the battery to get it started after swapping alternators. 1 Quote Link to comment
2wheel-lee Posted December 14, 2017 Report Share Posted December 14, 2017 Check to make sure you have a good ground from the engine to the body and from the body to the battery. I like to have a 3-way with 4 awg minimum: Battery to engine, battery to body, and engine to body. Make sure the ground wire goes to shiny metal where the paint is removed. Seal up after the connections are made. 1 Quote Link to comment
Pacific coast Datsun Posted December 16, 2017 Author Report Share Posted December 16, 2017 Good info for sure thanks. I'll report back what I find / have to do to fix this issue. 1 Quote Link to comment
Pacific coast Datsun Posted December 21, 2017 Author Report Share Posted December 21, 2017 Ok I added a ground strap from the block to the firewall & a ground cable from.the negative of the battery to one of the bumper bracket bolts & theres also a cable from the block to.the negative on the battery. I then tried to get a reading off the Alternator using my multimeter with no results & yes I tried both red & black.probes on both Alternator plugs. I ran the truck for awhile with the headlights & high beams on & they stayed bright. Ill have to test drive it at night to see if the lights dim again. 1 Quote Link to comment
gene knight Posted December 21, 2017 Report Share Posted December 21, 2017 pcd: i have a 16 gauge wire from negative battery cable to radiator hold down bolt and have no issues and a cable from block to frame Quote Link to comment
Charlie69 Posted December 21, 2017 Report Share Posted December 21, 2017 Mark I always have a frame to bed ground strap on the 520s and 521s, Cant hurt to add one on your 620. 1 Quote Link to comment
Pacific coast Datsun Posted December 22, 2017 Author Report Share Posted December 22, 2017 Good info guys TY. What was wierd that I wasnt getting any reading from the Alternator when I put the Multimeter probes on the Alt. plugs. 1 Quote Link to comment
Charlie69 Posted December 23, 2017 Report Share Posted December 23, 2017 Might help to practice with a known working system to help understand the functions of your Multimeter. Quote Link to comment
Pacific coast Datsun Posted December 23, 2017 Author Report Share Posted December 23, 2017 I was shown by a friend what setting to put the multimeter on to test the Alternator & got a reading off the old one. If this makes a diffetence thd Alt I swapped on.was on the boat & its a 60 amp output. 1 Quote Link to comment
Charlie69 Posted December 24, 2017 Report Share Posted December 24, 2017 If it is a 60 amp output then it has a built in regulator. Is your wiring setup for an alternator with an internal regulator? Quote Link to comment
wayno Posted December 24, 2017 Report Share Posted December 24, 2017 The 74 620 has an external regulator, so if the wiring is stock the alt will need jumper wires at the regular plug or need to be wired properly. 1 Quote Link to comment
Pacific coast Datsun Posted December 24, 2017 Author Report Share Posted December 24, 2017 Years ago I rewired it to accept an internally regulated Alternator. 1 Quote Link to comment
Charlie69 Posted December 24, 2017 Report Share Posted December 24, 2017 Mark take your 2 alternators down to an auto parts store and have them test the 2 alternators. Quote Link to comment
