VG30E swap questions.
  • Please log in to reply
34 replies to this topic
#1 thisisastickup
thisisastickup
  • Members
  • PipPipPip
  • 194 posts
  • Cars:'71 510, '08 silverado.
Posted 30 September 2009 - 12:25 PM
So I have a lead on a motor, trans, ECU, and wiring harness for my swap.
What all will I need? and What modifications will I need to do to my car to make the swap work?
I have this list:
-Engine
-Tranny
-NA ECU
-Wiring Harness
-what else should I add here?
I know Experimental Engineering makes a swap kit, what all from their site do I need?
Thanks for all the help.
teenager erection viagra in the water, erectile dysfunction. penis erection photos,erection tank erection weak erections and a poor seamen volume, erection during sleep, erection erection, erection erection system, nipple erections penis size erection major erection what will bring back my morning erection erection, peepee erection nifty preteen erection, erectile dysfunction, small boys with erection
#2 bonvo
bonvo
    Dr. Frankenstein
  • Senior Member
  • PipPipPipPipPip
  • 9,238 posts
  • Cars:73 datsun 610(the zombie 610) 76 datsun 610(r.i.p.) 56 chevy 3600 78 subaru goon
Posted 30 September 2009 - 12:41 PM
follow this link it will be your best friend
http://www.vg30.com/510vg30parts.html
the first rule of Ratsun is you don't talk about Ratsun... no wait thats fight club.....
....the first rule of Ratsun is PICS OR BAN! :fu:
http://community.ratsun.net/topic/3434-610-street-demon-resurection/
http://www.build-threads.com/build-threads/dedication-datsun-610/comment-page-1/#comment-5259
#3 thisisastickup
thisisastickup
  • Members
  • PipPipPip
  • 194 posts
Posted 30 September 2009 - 12:53 PM
Yeah, I've seen that, I should have mentioned that.
I'm wondering if I need to shorten my driveshaft or other shit like that to do the swap.
#4 bonvo
bonvo
    Dr. Frankenstein
  • Senior Member
  • PipPipPipPipPip
  • 9,238 posts
Posted 30 September 2009 - 12:59 PM
the driveline will probibly need to have the spline end changed to match the vg trans and yes it will probibly need to be shortened
#5 Icehouse
Icehouse
    wolf man
  • User Administrator
  • 5,068 posts
  • Cars:59 1000 4 door- 64 VW microbus camper special - 2 68 510 2 door - 73 Sunny truck
Posted 30 September 2009 - 02:59 PM
The DL splines will be fine unless your using a Z32 trans then it will need the z32 DL end... The Z31 nissan trans. I've never checked the Borg Warner trans. Someone needs to do an awesome writeup for every common engine swap!
Posted Image Posted Image
"All men by nature desire knowledge."
Aristotle
#6 yellowdatsun
yellowdatsun
  • Senior Member
  • PipPipPipPip
  • 1,618 posts
  • Cars:71 510, 72 510, 81 280ZXT, 98 Frontier
Posted 30 September 2009 - 03:16 PM
The BW trans has a different spline altogether. You will have to shorten your normal driveshaft to use with the swap. Make your mounts first and get the position right, then measure for the driveshaft.
Go to some shows and take some detailed pics of VG swaps, they will answer a ton of questions for you, and be usefull as your swap progresses.
#7 thisisastickup
thisisastickup
  • Members
  • PipPipPip
  • 194 posts
Posted 30 September 2009 - 05:04 PM
Unfortunately, I don't know of any vg30 swapped dimes in my area. In fact, the only 510 I've ever seen in person is my own. I'll be getting the BW T5 tranny, can a driveline shop match the splines for me?
#8 yellowdatsun
yellowdatsun
  • Senior Member
  • PipPipPipPip
  • 1,618 posts
Posted 30 September 2009 - 06:23 PM
I doubt it, the BW splines are different than everything else on the planet. Get a driveshaft out of a BW equipped car. Almost nobody runs the BW box with a VG30 though, I don't on mine. If I was you I'd just run a standard box unless you already have the BW unit.
#9 cjr198car
cjr198car
    Member
  • Senior Member
  • PipPipPipPip
  • 300 posts
  • Cars:Datsun 510/Nissan Pathfinder
Posted 30 September 2009 - 07:34 PM
If you need pics I can snap some for you. I have team thump kit.
#10 Jesse C.
Jesse C.
  • Senior Member
  • PipPipPipPip
  • 1,108 posts
  • Cars:72 Datsun 510 2 Door, '08 Nissan Xterra
Posted 01 October 2009 - 06:51 AM
I would not use the T-5 at all! It is too damn big and will require lots more work to get it in. Trust me, it is not worth it. A friend of mine had one in his conversion and did not like it at all!
From what I know so far, since I have not started bolting stuff up yet, the Z-31 spline should work with the 510 shaft but it will have to be shortened.
I believe there is a size specified for the driveshaft on VG30.com but it would be best to just measure it yourself and have it cut to your specs.
BTW, I have some 200SX exhaust manifolds if you are looking for some.
#11 thisisastickup
thisisastickup
  • Members
  • PipPipPip
  • 194 posts
Posted 01 October 2009 - 12:38 PM
That'd be awesome. I was actually hoping you'd chime in. Can I still get the team thump kit?
#12 cjr198car
cjr198car
    Member
  • Senior Member
  • PipPipPipPip
  • 300 posts
Posted 01 October 2009 - 09:23 PM
Not sure, drop Jeff a line @ jeff@teamthump.com. The main differences in the vg30.com kit and team thumps would be the engine mounts. Team thump uses the factory VG isolators. I think both are great kits. Im not an engineer so I cant tell you if the VG isolators are big improvement over the vg30.com setup. I can tell you that Ive never had any odd drivetrain noises and I have absolutely no vibration at idle. The kit has been in the 510 since 2003.
The only concern with the team thump kit is the lack of headers as an option. From what Ive read and pictures that Carter from vg30.com has sent me the vg30.com headers will fit the team thump kit without modification.
What pics would you like (firewall clearance, engine mounts, engine height, etc)?
-Colton
#13 Icehouse
Icehouse
    wolf man
  • 5,068 posts
Posted 02 October 2009 - 10:10 AM
I always thought the nissan vg30 trans was the same as a KA trans but Shawn has the nissan vg turbo trans and he said the splines were different than the 510 DL ones... Maybe the non turbo trans have the same DL spline size and count.....
Aristotle
#14 thisisastickup
thisisastickup
  • Members
  • PipPipPip
  • 194 posts
Posted 02 October 2009 - 12:21 PM
-Colton
I don't really know what I want pictures of. I guess I'll be asking more questions when I start doing the swap, so I'll probably ask you.
Is the wiring hard to do, and are there any writeups on it anywhere?
#15 cjr198car
cjr198car
    Member
  • Senior Member
  • PipPipPipPip
  • 300 posts
Posted 02 October 2009 - 03:06 PM
I run a stand alone (tec3). I would get a manual and wiring a schematic.
#16 yellowdatsun
yellowdatsun
  • Senior Member
  • PipPipPipPip
  • 1,618 posts
Posted 03 October 2009 - 06:29 PM
If your using a stock efi setup the wiring is cake, there's only about 5 wires to connect between the VG30 efi harness and the 510 harness. But ask again later when you are to that point and someone can help you with it.
#17 thisisastickup
thisisastickup
  • Members
  • PipPipPip
  • 194 posts
Posted 03 October 2009 - 11:27 PM
sweet, yeah I'll be keeping the motor bone stock for now.
#18 chumstone
chumstone
  • Members
  • PipPipPip
  • 230 posts
Posted 04 October 2009 - 03:20 PM
I bought a 2 door from Jeff that he had his Team thump (of course!) VG30 engine swap mounts and pan. I now have a wagon that has the VG30.com motor mounts and I cannot tell the difference. I also installed the VG30.com headers and that is the route to go or you will have to find 200 SX manifolds to be able to get the starter out and etc.
Since my wagon engine has Isky cams, polished and ported heads, the headers just compimented the the above and puts out way more power than stock.
I'd go VG30.com for ease of getting the mounts and the fact that you can always swap to SR20 or back to the 1600 engine.
What ECU and wiring harness will you be running?
72 VG 30, 4 link wagon, 170 HP, 180 TQ
#19 thisisastickup
thisisastickup
  • Members
  • PipPipPip
  • 194 posts
Posted 04 October 2009 - 03:54 PM
All stock for now. I can get an NA ecu and wiring harness. I'm going budget for now, I'm a broke highschool kid right now. I just want the car to run good and smooth, I'm not worried about performance although it should be plenty fast.
#20 thisisastickup
thisisastickup
  • Members
  • PipPipPip
  • 194 posts
Posted 29 November 2009 - 01:34 PM
K, new question. Will my scirocco radiator work for the swap?
