720 upgrades
  • Replies 7
To do the brakes you'll need everything from the spindle out. I'm using 95 frontier brakes on my 78...79...or whatever....there's so many different years in my truck...I mean in my boxes and piles all over the garage :P
You'll also want to grab the rubber brake lines an bango bolts.
Easy upgrade to newer style calipers ;)
Not sure on the steering but you might be able to cross reference the part numbers. I know the 521's and 620's use the same steering components. Never checked the 720's though.
Either way you should be able to buy new steering components for the 720 at any parts store. I would go new for the piece of mind.
Nice truck BTW. I used to have an 80...good times in that one :D
Suspension, steering, brakes and maybe interior pieces. 720s are a little thin on the ground here. Most seem to have rusted to death years ago.
Around here the '78 620 through '83 1/2 720s had the same pathetic discs and calipers. I think in '84 they were up-graded to vented discs and larger calipers and should just slide on. The 4X4 would be different. Check it out.
