Pacific coast Datsun Posted February 14, 2007 Report Share Posted February 14, 2007 Ok today Ryan helped me install my electronic distributor out of a 610 into my 620. I used a GM HEI module instead of the remote ignitor box & wired it in with instructions from Mklotz. Im only mentioning names cause i know these guys know Datsuns very well. Anyways we get finished & fire it up & it starts right up...runs good for a minute then dies. I try to start it up right away & nothing, just cranking. After a few minutes I try again & she fires up but dies 20 seconds after that. I was chatting with Ted & he thinks it may be a bad coil or a faulty module. The truck does have gas & we didnt adjust the carb during the dist. install. Also im using the coil that was in the same car the dist. was in, on it it says for use with elec. ignition Any other ideas on what is causing this?? Heres the coil & dist. im using... the HEI & new coil... the vac. advance sits in a diff. spot... Quote Link to comment
71-521 Posted February 14, 2007 Report Share Posted February 14, 2007 hmm...seems like Hainz used to rant about ohms and such over on the other site...I think steve knows his shite as well... wish I could help ya but I'm slowly forgetting my electricity training. Quote Link to comment
Bleach Posted February 14, 2007 Report Share Posted February 14, 2007 you don't need any kind of resistor on an electronic ignition coil. That should just run. In a Z, if this happens its always the IE module on the side of the dizzy getting too hot... well, when it starts to go out it will do this when it gets warm. I don't know if its due to engine heat or just that it heats up from use. Yours is mounted far away from the engine. Maybe it is a bad module... snag a free one from the wrecking yard. Subaru.. ;) Quote Link to comment
Icehouse Posted February 14, 2007 Report Share Posted February 14, 2007 I say put the old coil back in, I ran the same dissy with a blaster 2, that whole ohms crap, resistors are for points. If that doesn't work get back to us, I doubt it is the dissy, because its a pick up, why would work then not work. I have heard if the HEI module is backwards it will run just poorly. Lets take it one step at a time. Coil first then something else. Quote Link to comment
Pacific coast Datsun Posted February 14, 2007 Author Report Share Posted February 14, 2007 Ok Ill try using the old coil & see how she does. I remember reading somewhere that if you dont run the right coil w/ an elec. dist. it may get hot & stop working?? Ill try it in the driveway & get back. BTW heres an action shot of Ryan ...:D Quote Link to comment
Icehouse Posted February 14, 2007 Report Share Posted February 14, 2007 You bastards hanging out in the sun! Quote Link to comment
Bleach Posted February 14, 2007 Report Share Posted February 14, 2007 Ryan's making sure he has fresh breath while Mark works on the Datsun. Quote Link to comment
Pacific coast Datsun Posted February 14, 2007 Author Report Share Posted February 14, 2007 Ok based on the advise given here & a few IM's [yahoo] from Bleach ill try & hook up the "old" coil & see how it does. I want to also test the "new" coil for power & see if it needs to be tossed or can still be used. On a side note I also had some advise form a well known Datsun person not on this forum yet...:rolleyes: Quote Link to comment
Icehouse Posted February 14, 2007 Report Share Posted February 14, 2007 Let me guess a poorly spelling? Gets a hard on over points conversions? Made a 4hrs L motor video? Hainz? I talked to that old fuck yesterday on the phone, he sure is a great guy. He quite the forums because he no longer daily drives a datto. He is a jeep/hunting guy. Another one bites the dust. Haha I'm just talking out of my ass now :) Quote Link to comment
Bleach Posted February 14, 2007 Report Share Posted February 14, 2007 I should buy his beater for $500. :D that guy can assemble an entire L-series in 4 hours. haha! Quote Link to comment
Pacific coast Datsun Posted February 14, 2007 Author Report Share Posted February 14, 2007 I went out & reinstalled the "old" coil & fired the truck up. Started up good...ran for 15 seconds then died again. Let it sit for 3 minutes tried again & 15 seconds later she died again. Im thinking it may be a bad module even though it's "new". I need to buy a multimeter & check how many ohm's go to the coil. & yeah the "other " guy who is helping drives yellow convertable...:cool: Quote Link to comment
Cuts metal like mad Posted February 14, 2007 Report Share Posted February 14, 2007 Bet he told to you just do a pertronix... hes probably right too... Quote Link to comment
71-521 Posted February 15, 2007 Report Share Posted February 15, 2007 I should buy his beater for $500. :D haha! and I would buy his truck (minus engine and trans) for 300! Quote Link to comment
Pacific coast Datsun Posted February 18, 2007 Author Report Share Posted February 18, 2007 Ok the problem is fixed!! Turns out the ground screw wasnt going all the way through the fenderwell & the module wasnt grounding. I drille dout the hole & used a longer screw & there you go...fired right up & wow! Differences now are... starts easier & faster.. smoother idle.. better acceleration.. kinda hauls ass now..:D And after using the site links you guys posted I found out I still need to mount the HEI to a thin piece of alluminum to keep it from getting too hot. More pics to come & thanks again! Quote Link to comment
Icehouse Posted February 18, 2007 Report Share Posted February 18, 2007 Dude I almost said something about grounding the unit..... son of a ** haha It looked good in the photo's you posted. I had the same problem when I did the same conversion in one of my 510's years ago. I'm glad you figured it out. Quote Link to comment
